Hmmm. Well in the process of my alarm installation we've found my car used to have a boost controller, turbo timer and some sort of temp gauge. Also my standard boost restrictor has been removed.
Now with that removed and a catback exhaust my installer seems to think I'd be running atleast 14psi and he says I'm risking detonation because my timing or something might not be right and that I should hook up a boost gauge to know exactly how much psi I'm running and he can make it so I don't run the risk of detonation.
Is he talking shit or should I be concerned?
I found a turbo timer when I had my alarm installed. Was all hooked up, working... just was tucked under the dash in the footwell. You find crazy shit under there.
I thought without the restrictor, it runs at 12psi?
Mine still has the restrictor, so I have no idea.
  • Replies 14.2k
Man knows his stuff. Boost gauge is invaluable, esp when you simply don't know all the variables (ie condition and internal construction of turbo, afr's with the current tune, etc etc).
I still got a tonne of shit wiring above my drivers side footwell, thats after removing the old security system and turbo timer and replacing it with a decent ADR compliant one. Loads of bad japanese engineering (read: bits of wire twisted together and taped with racing tape) as well as wires leading from my spotlight button to the thermofan (i didnt realize japan got so hot they needed a thermostat override, meh)...
Another job for me to do next time I find a compelling reason to pull my dashboard off
-D
Dion, if u read this. Was just looking at the engine u brought, you do know u have to pay aus customs, quarantine, agent fee's, docking fee's, storage fee's on that engine when it arrives here? roughly another 800-1k on top of the buy it price which streeter has quoted u.
Lol same. kicked mine by accident and saw a blue flash, then the car wouldnt turn off lol.
I lived in Japan for a stint many years ago. On the Kyushu island, mainly in Takanabe, and it got hot there in summer. Weather was almost identical to Adelaide's ... so I wouldn't be surprised.
:bunny:
ouch.... i hope he did realise this, he seemed to think it was a fair cheap engine :bunny:
sooooooo.....
who wants to give me a hand sunday, need to bolt the engine and gearbox in??
got captain thread comin out tomoz morning to get the 3 broken studs out, quoted $110.
ill put the motor in minus turbs as ill need to grab new gaskets/studs etc and wont have time before sunday....
theres Beer in it for ya.......
please.......
BJ inc
sooooooo.....
please.......
BJ inc
sheeeet, just remembered i hadnt grabbed them engine mounts yet.
tell ya what, i'll grab em tomorrow and either send them your way with one of the boys, or sat nite im heading to redwood park so can drop them off to ya
i just bought a grands worth of shockies for my race car from the states and didnt have too pay any extra tax on them customs had opened the boxes and re taped them shut
I've had quite a few items sent over from overseas worth more than $1K+ and have never had to pay tax on it, yet I have heard of so many that have had to.
Anyone here know spark plugs?
What are these telling me about how my cars running?
Also some new clamps :bunny:
The ends seem to be the right colour, so it tells you it is running right. If you saw plugs that i took out of my car a few weeks ago you would have seen it was running wrong, which now reminds me i need to check the condition of the new plugs.
haha no worries mate.
yeah im planning on dropping the motor in on sunday, as Dale's bro in law needs the crane back, for
a long time by the sounds of it, poor bugger...
yeah if you cant grab them let me know, as ill be down south tomorrow and could possibly grab them??
i got an idea, how bout you bring them to me sunday and give me a hand?? :bunny:
yer mitch, ill be there.
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
