Nah got the pump priming. Doesn't even come close to firing up though, just turns over for a bit while draining the shit out of the battery, even when being jumped and the other car is revving a fair bit, it still almost dies completely.
My mate said he could hear the fuel being pumped into the rail, so it might be a spark issue, but I really don't give a fuck anymore. It's time for someone who knows what they're doing re wiring to have a suss (that or it's time to push the cunt over a cliff and gleefully watch the destruction that ensues)
Edited by AndrewJZX100
  • Replies 14.2k
Brand new plates too Mitch :D
o noez haha
Yo Donkey Kong, you should buy my KTS Tie Rod ends - increase steering lock = fully sick hectik driftz :)
sorry peach , if im gonna buy anything for lock it will be drift knuckles
Can you check for spark? Remove one of the coil packs and stick in a spark plug ... crank it over and check for spark? Or timing light if you have one.
I just can't stand to look at the thing at the moment. My mates dad has a multi-meter but none of us who are working on it have a clue about wiring so I guess we've done pretty well to get this far with all the bullshit little differences/problems we've encountered :D
One thing though, Nissan can suck a huge wang. Why the hell would you make every single goddam sensor have a different plug between 2 engines of the same vintage fitted to similar chassis?
UUUGGGHHHH marry me Andrew??
im right there with ya mate, couldnt even get the RB on the engine mounts today,
and Dale needed the crane back ASAP, si i dropped it onto one mount just so its in there
ill take it to a shop and let some other douche deal with it.
between work, My Boy and other duties, i no longer have the time of patience anymore.
FCKING CARS!!!!
gonna do the worlds biggest skid when its done i swear!
FCKING CARS!!!!
LOL we've both come to the same conclusion - some other sucka can deal with it :D
Tandem skids when both our shitboxes are done fo sho.
It wouldn't be so bad if the end result was some bullshit tough motor, but all this shit for a 20? :D
Nah in all honesty mine wouldn'tve been half the headfuck it has if me and my mate didn't make an important decision re how to swap looms while absolutely plastered last weekend :) that was where the real troubles began.
Nah in all honesty mine wouldn'tve been half the headf**k it has if me and my mate didn't make an important decision re how to swap looms while absolutely plastered last weekend :) that was where the real troubles began.
try doin it for 8 months for a stock motor haha
Well I think my GTR has proven a new meaning to the term "GTR handle like they're on rails"
Aye thats well low.... what suspension u running? :P
I just got back from a 2 hour drive thru the adelaide hills, from hahndorf to lobethal and gumeracha as well as a few detours here and there, loads of great twisties, some nice sweeping bends and the odd straight road make for a great time. even got to drive on a single lane dirt road with a huge dropoff on one side... gtr lapped it up and asked for seconds
*sigh* so have to do that next weekend
-D
Wonderful! Pulled my RS250 race bike engine down and found some foreign metal in there. :P Appears some douche at the track didn't like a little 250 spanking him and his 1000 and put foreign bits (a piston pin not even for my RS) into my crank case when I left it unattended ... resulting in the clutch basket gear, gearbox engagement gear, and seals being wrecked. Now its rebuild time ... and I haven't started the season! :D
Might have found a race spec motor in Singapore ... waiting for confirmation.
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
