  • Replies 14.2k
farkin! bit big! you could photograph Tasmania from your balcony Troy.
its kinda like that...lol that is only part of it , another part doubles the 1300mm to 2600mm. its like waist high now from the floor..lol
took some other photos with them the other day,,,but its so amazing you cant tell how far away it is of a kite surfer. he was a few K's out at least
if your a lay person like myself, this is a good read, how a rotary engine works.
http://auto.howstuffworks.com/rotary-engine4.htm
Rotary engines rock,,, rev like hell , sound isnt as smooth but still goes like hell
get used to them you might have one someday
http://www.autoweb.com.au/cms/A_55754/titl...ewsarticle.html
+1. Alot of people don't like the sound, I'm quite fond of pp/bp and turbo rotaries. Probably still to this day, a rotary is the fastest car I've been in...
Hmmm..
Cars making big ass clunking noises over bumps like the coilovers don't want to stay under the guards. All bolted up mint and tight too. Don't know wtf going on.
do u have adjustable camber arms? thats the noisiest component of my suspension
-D
I have nothing. It's actually like the coilover is about to fall out. Took the wheel off with Wayne earlier and all the bolts are tight. Shook the coilover and right at the top of the going it makes a knocking sound. I don't know if anything is hitting anywhere. But it wasn't making the noise yesterday
sounds like the bump stop needs replacing (if it even has one - some (like my old bilsteins) dont have bump stops)
-D
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
