hrm that looks good with white. methinks they'd look nice on my r32 >:)
-D
Well I'll have a set coming next week. So you can see what they look like. But I don't think you want the sizes I'm getting.. Bit too 'illegal' for your liking.
  • Replies 14.2k
yeah i think i'd be after 18x9 at most (34 gtr rim size) or the 8.5's.... but will be nice to see regardless
-D
much hope the 31 sounds like this when finished with side pipe
no craig, you want yours to sound like this
or this on idle
btw, my side pipe will be similar design and hopefully pop flames like such too
ok i just cant not post this, i know ill make a few of you blow your load.
http://speedhunters.com/archive/2009/12/08...31-skyline.aspx
fanki's car
lowest 31 in australia. loves munching front guards too
Edited by Matty 31
/chop images of pron 31
sounds O-K.....
thats how decs is gonna make my cooler piping, looks like shite, but atleast its much shorter...
Kye, can you link my aquarium to NS.com for me dude?
cheers
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...=STRK:MESELX:IT
just did it craig
http://www.nissansilvia.com/forums/index.p...howtopic=419835
Does anyone know if regency will accept R32 GTR front brakes instead of R33 GTST front brakes when registering a 25'd 32?
Here is the part about that in my letter: 10. That Nissan R33 296mm X 30mm disc brakes and calipers are fitted to the front axle.
If I have to use them its fine, but my understanding is that brake wise R32 GTR > R33 GTST. Maybe I should give them a call and ask..
I think r32 gtr non-brembo brakes are the same as as r33 gtst brakes anyways
ugh. went to the dr's about my sleeping and anxiety issues, instead of finding a solution, "heres some drugs, enjoy." f**kin.
anyone got suggestions on what torque to do a hubcentric bolt on spacer up to ?
110nm + some loctite.
asking for a little help
posted in borrow section too..
me 'na mate are rebuilding a suzuki f5a 543cc 3cyl hatch atm, engine is out on ground
cant get the flywheel off, etc.
need to borrow a flywheel stopper holder lock tool
anyone?
anyone?
rattle gun works a treat ;D
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
