  • Replies 14.2k
\m/etal. get andrew to make it up for 150 or something. found my hks one on a 2nd hand engine at jis for about that. ha.
... or just buy that ebay one. i would.
good value for money , even my engineer said it was good quality.
comes with all silicone and hose clamps aswell
silly question but does leaving your car in 1st and turning the car off do damage to anything.
oh nooos..... you have def blown your gearbox now,
you had better sell it to me as a spare...i give you $50.
Progress Report:
Luke and I got the tiptronic box out of the Stagea today ... those things are f**king heavy!!!
Next step is to fit the Exedy flywheel and clutch kit to the crank, then put the manual box in place.
Thanks a bunch for the help so far Luke. >_<
At least Stags aren't like alot of old cars, with two different cranks for auto and manual. Good to hear its all going well Ruby.
Well JJR delivers once again. Fitted my Autech copy catch can and my ARC copy washer bottle/catch can today!
While I'm here ...
Can anyone tell me, or point me to a link, as to how a GTR/260 gearbox pull-type clutch fork mates up with the pull-type clutch kit, so the clutch engages properly. Push type I know you just slide things on. But is there a trick to fitting the GTR box to a pull type pressure plate and carrier?
Thanks >_<
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
    • If you do make them, im sure you would have a number of buyers.. Every GTR I've been in have rattly door windows
