I think you will find that the rear end isn;t slipping but the HICAS is loosing is shit and letting the rear end track where ever it wants, which would explain why the HICAS light is flashing, It could be as simple as air in the lines. I'd also check the fluid levels for the HICAS/Power steering.
he has a hicas lock bar.
-D
  • Replies 14.2k
just won what looks like a twin plate clutch for sweet f**k all money. pick it up friday and take to acs to see if it needs a rebuild. even if it does itll work out cheaper than the clutch i was looking at.
i just won this http://www.graysonline.com/Lot.aspx?id=4324739
and this http://www.graysonline.com/Lot.aspx?id=4324916
for a grand total of $68 plus 13.5% which goes to JMS. awesome!
Would an exhaust for a R32 GTR fit a R32 GTS-t with modded hangers? Gotta sell this exhaust that I bought from RBWARE and would make it easier if it could fit both GTR and GTS-t lol
I think you will find that it might not fit through the loop in the swaybar on a GTST/GTS4
I've had a good look under my car and a few GTR's and the GTR has a much larger loop for the zorst, i dont think i'd be able to run those twin pipes on my car.
nice dude, i was thinking about bidding on some seats so i could on sell them for a profit, i couldnt track the auctions from work. and getting the old man to track the clutch was hard enough.
but yeah, picked this up for $49 +13.5%.
not many details (read, none at all) but its for an sr, and it looks pretty beefy. ill pick it up friday and take it down to acs so they can have a look.
Demonoid is back! :cool::(
i could almost cry im so happy right now.
Edited by scandyflick
While I'm here ...
Can anyone tell me, or point me to a link, as to how a GTR/260 gearbox pull-type clutch fork mates up with the pull-type clutch kit, so the clutch engages properly. Push type I know you just slide things on. But is there a trick to fitting the GTR box to a pull type pressure plate and carrier?
Thanks :cool:
^^^ Can anyone shed some light on this Q?
Luke and I finally got that damned bearing out last night for the auto box and fitted the spigot bearing for the manual box. Nismo lightened flywheel and HD clutch kit ready to go on once I replace the crank seal.
Anyone wanna help with putting the manual box in on Saturday morning? :(
I know 95% of SAU aren't clubbers...
But for the 5% who are... Can you remember Church the nightclub? Amazing place back in the day. Filthy shit, but f**k it was awesome. Then they got shut down a few years back after one too many leb fights/underagers getting in and shit like that.
Well, after sitting dormant for a few years, it's re-opened... into...
Applebar!
It's a pretty 'exclusive' club spinning pure house music. Cocktail bar on Level 2, Dance floor on level 1 and a smoking area on level 3 apparently.
Check out how much this shit has changed, though:
Good to see Adelaide getting some more of these types of clubs. Sure, the filthy places are fun, but these kind of places are also real good fun since you don't get all the tools in there.
I'll have to check it out on the weekend I think.
Anyone wanna help with putting the manual box in on Saturday morning? :P
Me Me Me....I shouldn't be working this Saturday, so i shall lend a hand.
fark i just got ripped 30 bucks and boy am i pissed . i bought a tiger woods dvd called 18 holes AND IT'S ABOUT f**kING GOLF !!!
Applebar!
going by the individual behind the concept of this whole applebar joint, this will be one very classy club. I'll put dollars down to say this joint will be extremely difficult to get into if you're below 25, look wasted, aren't dressed to impress, or don't know the club owners. And again, going by the individual behind it - deep/soulful/disco/tech/prog/underground house. No trashbag electro shit you hear around EC, HQ etc.
I can't wait to check it out :)
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
