that with or without club discount :)
With out man, should still be able to get it cheaper through my jap mate tho :ninja:
btw come and pick ur old clutch up from the workshop :D
doing a mass clean out.
  • Replies 14.2k
yeh, the wheel on it is slowly getting hammered from doing gangsta flare jobs so can only do a slight roll.
Also just went to shannons dropped 1k off my insurance cause the cars not in a driving state atm yay.
Also big thanks to Blue32 (Andrew) for doing a awesome port job on my stock 26 manifolds :)
na i dont need a flare, that would be just for added wank. lol
let me know mate, i have the car here till friday, i just hope we can push it onto mattys trailer lol
otherwise, its hammer time
Edited by craig R33
need 215/225x35/40xR17 tyres asap!!!
lemme know if anyone has...
I can give you my mates number he works at Southern Tyre Disposals, I got a few 15's off him this week. Just not sure if he'd have any that size
ill give sinergy and used tyre mart a call first mate, if no luck ill hit you up!
i tried ridgehaven tyrepower, and adelaide radial tyre at ridgehaven with no luck.
should prob try holden hill aswell.
try tyrepower behind BP
my mate works there and im sure they have a few 17s
Husband and wife are lying quietly in bed reading when the wife looks over at him and asks the question.
WIFE: "What would you do if I died? Would you get married again?"
HUSBAND: "Definitely not!"
WIFE: "Why not? Don't you like being married?"
HUSBAND: "Of course I do."
WIFE: "Then why wouldn't you remarry?"
HUSBAND: "Okay, okay, I'd get married again."
WIFE: "You would? (with a hurt look)
HUSBAND: (makes audible groan)
WIFE: "Would you live in our house?"
HUSBAND: "Sure. It's a great house."
WIFE: "Would you sleep with her in our bed?"
HUSBAND: "Where else would we sleep?"
WIFE: "Would you let her drive my car?"
HUSBAND: "Probably. It is almost new."
WIFE: "Would you replace my pictures with hers?"
HUSBAND: "That would seem like the proper thing to do."
WIFE: "Would you give her my jewelry?"
HUSBAND: "No. I'm sure she'd want her own."
WIFE: "Would you take her golfing with you?"
HUSBAND: "Yes. Those are always good times."
WIFE: "Would she use my clubs?"
HUSBAND: "No. She's left-handed."
WIFE: - silence -
HUSBAND: " . . . DAMN !!!
anyone heard of some kind of sealent called hollimar? hollamar? etc etc
apparently its good and i should use it but got no fkin clue what its called
Its Hylomar, OEM spec sealant and yes its freakin awsome stuff :)
Copious amounts of incredibly talented girls at brighton yesterday afternoon/night whilst doing some fishing :)
Impressed and will go back even though the fishing wasn't great!
you gonna be there tonight Steve?
I'm catching up with a few mates at O'Halloran Hill Buongiornos tonight for a feed and may do Brighton and the Bay esplanades on the bike aroung 10 ish.
Would be good to catch up for a drink at the Espy Hotel.
speakin of fishin, im considering going to ardrossan or cape jervois next weekend (when its not 40'c ffs) and grabbing some squiddies, garfish and blue swimmers... anyone else feel like comin down for a days worth of laziness on the jetty?
-D
I had intentions of going down again tonight but fell asleep watching the news and only just woke up now when the mrs called my phone!
-D
Should be good, I can't next Saturday because of a wedding but I should be able to if you're going next Sunday
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
