good on ya cara for having a smash! but chille! on a much much much more impotant not how the hell do i get my drivers side front drive shaft out HELP HELP its killing me shaft sorta seperated dunno if i broke it or its meant to seperate.. cant wedge anything in to pop it out!
  • Replies 14.2k
Not quite sure where you're coming from Cara, no one had a go at you :/
+1
I was making one of my usual 2 wheeler (motorcycle) jokes, if thats what set you off.
And for the record I've been involved with the Motorplex Consortium for over 6 months now ... attended the rallies, meetings and discussions to get our drag strip happening ... I drag raced for over 4 years at AIR until it was closed on both 2 and 4 wheels ... and that included 40+ degree heat in full leathers.
:D
Ruby wears more leathers than your average german pornstar >:D
-D
thanks mate! i managed to track down an engine crane from a mates dad aswell!! so were lookin sweet appart from a few tiny things now!
shouldnt you be getting moto storm matty for your off road fix?
on the plus side normsta will get to the see the sun still being summer now. ive done 14hr shifts during winter and only got a glimpse of it at 6.30 in the morn.
Edited by Inline 6
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
