  • Replies 14.2k
category 1 (< 15km/h) = 1 point
category 2 (15 - 29 km/h) = 3 points*
category 3 (30 - 44 km/h) = 4 points
category 4 (> 45km/h) = 6 points (and a $564 fine + $30 levy, lol)
*same as failure to stop at a yellow or red light.
ive now been fined for everything but a cat 3. not a great record.
fixed
*same as failure to stop at a red light.
45+ you also receive a summons to appear for "speed dangerous to the public".
so... in 28 days ill be losing my licence. bit of a bummer. but they couldve raped me pretty hard.
copping a 6 month suspension and a $600 fine. but considering what they couldve done me for, that isnt too bad.
dw mate send it this way ill look after it real good :banana: we can has hillzy every weekend
you possibly have very bad phone lines or live like 7km's from your exchange, the further you are from the dslam the more 'overhead' you loose (my terms and thinking may not be 100% correct but very close :)
you dont want to see mine :banana:
EDIT
log on to router, and there should be a status page there that tells you all you need to know
it also depends on the line profile selected on the internode end - you can check this/change this using your account login.
also if you log into your modem, ensure that it is set to use G.dmt modulation rather than g-lite or ansi
Another thing to do is to disconnect every phone device from the phone extensions in your house (including line filters) and just run the adsl router by itself - if you notice that there is a speed increase after doing so then it points towards attenuation on the line due to either a faulty line filter or bad cabling.
-D
-D
no idea on were to go.. hehe..
If it is a Billion modem, open IE/Firefox/Chrome. In the address bar type 192.168.1.254, you will be asked to log in, Username: admin, Password: admin. You shall now see the status page.
All other modems will be similar, only differences being the IP address and maybe the log in details.
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
