  • Replies 14.2k
is there kits you can buy to replace all the hose's on a rb26. i thought i seen em somewhere but i can only see heater hose kits around.
i had a tiny leak in the radiator bypass hose but was thinking i might just replace them all for piece of mind.
apparently that 1 bit of hose costs $70.
Edited by Inline 6
Hey i went there and watched.. and it was hot as balls. I thought about putting my car down the strip but it was way too hot for it. so i just watched all action from the stands. there were a lot of nice cars out there.
thanks for coming and saying hi then :banana:
ok pop quiz, who can tell me what this hose is called or what it does exactly.
starts on left side of motor here, did lil angle. top of the pic you can see where it starts to say rb26 if you not sure where it is :P the hose im talking bout comes off near the large top radiator hose and heads to the right side of the motor
in which its hard to see exactly what its doing under nearth my turbo piping here. its the lower of the 2 skinny hoses here
just started leaking coolent on me, fortunately i only drove for about 2k when it happened and its a tiny pin hole so coolent was still full.
sale of wheels saga, entry number 46734:
found another dude whos keen, some random apprentice that owns a hr31 coupe, shall be collecting a deposit soon. rad.
any suggestions for new wheels?
viennas, hanging 12 miles out the guards
overfender the f**k outta it
then see if ya can get stickered before ya lose ya licence lol
*edit*
ive got nothing lol
Edited by Matty 31
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
