  • Replies 14.2k
lol, ebay rocks
panasonic blu ray home theatre system, (inc sub and 5 speakers etc etc)
grand total of $142.50.
i half expected it not to work for that price, but it looks and plays like brand new!
win
When u got the right tools, some know how and some mates who know how to help out it really does help.
Got Andrew coming down Monday to start with the engine. Hopefully I got everything now.
Next is some nismo parts to freashen up the front end. So hopefully in 2-3weeks it will be all running.
loving it mate! yoiur updates are still my source of inspiration!
fitted these saturday.. such a pain in the ass, alot of cutting and stuffing around and they still arent perfect but abit of black silicone should help
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
