  • Replies 14.2k
cos my foctory ones had hacks everywhere and i got em really cheap.. whats wrong man?!?! diddnt mean to offend ya :O
They just look ricey, more suited to a stripped out race car.
Edited by DSTROY
i know this, but when doing a 20 conversion, why not run atleast a side mount?
I'm going to say, because none of the standard piping etc would line up or at all be usable with a VL engine bay.
Too much hole cutting and chopping out airbox trays etc.
Be alot more effort then its worth, and why bother cutting a whole heap of holes in the bay when you will eventually upgrade to a FMIC. The crossover pipe is a great bandaid fix just to get the car moving imo so long as the car ran standard boost with std timing etc.
Maybe I am putting too much thought into this :\
stripped out race car!?!? u mean this?! hahahaha
lol! that reminds me, you keen on coming up to this http://www.loveday4x4adventures.com/Australian4x4Muster.html I might head up with my sister. I just want to win the Landcruiser that was painted up at my bro in laws paint shop :O
Looks like i better keep inspiring u Jenkies :O
On friday night my mate and i got stuck into fixing my battery tray from where battery acid had spilt before i brought the car.
First off was the cut the stupid thing out.
Then weld in a sheet of alloy.
Then add some primer.
Then seam sealer
Then use some tripple 2 s (think that whats its called) makes the paint stick like crazy.
Then on came the paint. :P
post-38653-1264324901_thumb.jpg post-38653-1264324955_thumb.jpg post-38653-1264324999_thumb.jpg post-38653-1264325081_thumb.jpg post-38653-1264325145_thumb.jpg
And thats how it is now :)
its ok, i have a 5 year warranty on stains and rips :rant:
you may want to give the warranty a close read mate.
i dont think ranga jizz is covered, something about it being biologically phucked up or some shit
and cant be removed with they cleaners they have....
just a story i heard.
too much thought :) easy as! i got a few lengths of stainless from paramount browns some second hand factory intercooler pipes from various workshops for free cut a few holes made a few brackets and hey presto! :) still vl's are in the past :rant:
lol! that reminds me, you keen on coming up to this http://www.loveday4x4adventures.com/Australian4x4Muster.html I might head up with my sister. I just want to win the Landcruiser that was painted up at my bro in laws paint shop :D
will have to see if i can get the time off but that would be awesome!!!
Looks like i better keep inspiring u Jenkies :P
Then seam sealer
Then on came the paint. :)
LUKE THATS INTENSE MATE!!! its more epic than karnivools new albumn :P
just a story... it sounds like an argument that you had when trying to return your lounge room curtains
hey hey. long time no speak. how is everyone??
i'm great, Amber is 10 months old today. she has kept me VERY busy, crawling around trying to get into all sorts. she's started walking along furniture hehe.
well i'll hopefully be on here more often :rant:
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
