will look tuff as nails on a HR31 for sure.
bundy...horrid? do you even have any taste buds?
whats do you drink? teds?
i got solid taste in drink. lol.
after work, teds get a pretty solid hammering (5 squid a pint, cant complain). my usual weapon of choice is cc dry.
when i want something different, ive got bottles of small batch, gentleman jacks, makers mark, other rad stuff like that.
and when im feeling really fancy, 22 year single malt glenfiddich, on the rocks (no more than 2 pieces of ice though).
Edited by scandyflick
  • Replies 14.2k
  1. Chad
    4. Safety 21 half cage for A31 Cefiro / C33 laurel - good nick, all bolts and mounting plates - $600
    Contact Dan on 0413 761 305
    i kinda know him, so can possibly get it cheaper
    I has sun roof :D
Edited by DSTROY
Wow ... was looking for something and stumbled across some old AIR time slips in my old race leathers from October 2004, from when I was drag racing bikes. :D
I've had these leathers 6 years and never wore them again after AIR shut down. Zipple (Motorplex) cruise tomorrow ... coincidence?
thoughts??
i think her body is smokin!!!
a little on the ''too toned'' side, but fit as!
missus was just watching her dvd and dayum........ needed a long (well short) shower lol
specially when she did ''i touch myself'' wow
thoughts??
A pretty talented chick, I dont really get into pop but at least her songs arent painful to listen to (and she seems to have a brain on her head...)
As far as attractive tho? Nah... little too dykey
I like curves n boobs
ala Laetitia Casta
Keep dreaming Doh...keep dreaming...
-D
Hey guys, I am having a sausage sizzle at my work tomorrow (Australia Day)
& I will be driving the R35. Any of you in the area around lunchtime are welcome to
cruise past & say g'day & grab a banger with sauce.
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
