The Sa Wasteland
heslo
 Share
  • Replies 14.2k
awesome
Ive got the $5 ebay bhp-steel roll cage, and mate is welding it in
stipping atm, half stuff sold.
got another 1g to get back in, once the seats/interior skins sell, etc
then need ku36 tyres,
track qfm pads,
powerfc (from fishpaste),
and injectors & tune
then ready for mallala :)
cheers mate!
yeh the zx9r is sold for 5600, awaiting deposit, didnt lose any $ on it - only rode 300kms in 8months :(
just the knees - cant do it.
so hence the r32 purchase; currently costing me exact same as the bike sale !
ie a swap over.
get it down to around 4500 in cost from 67000 purchase price,
then add in the bits I need
should be a $7k track car, TT at that!
~250rwkw at 1bar Id suggest
oh yeh, just won ebay a garrett 18psi actuator.
off goes the hks 14psi unit, on goes the manifold Ive treated and the actuator.
:):D
sled - no more bike. sorry before, months ago, but I took offence to something you said
re: bike, pension, ..... i made a complaint to andrew about it.
anyways, I reckon you're doing a bang-up job for sau:sa... keep at it. :)
only managed 300kms in total of rides on the bike, just couldnt do it without patella's
so yeh sorry for arching up months ago, you're a good mod for sau:sa so yeh kudos 2u :)
What you doing with the 14psi unit? :)
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
