shane is that on the stock hks wastegate taht comes with the manifold??
coz im thinking if i can get the gate running 14psi then i can set my eboost to run 14, 16, 19 psi?
should be sweet.. i guess i can try and if not upgrade..
  • Replies 14.2k
sorry Shane, just seen ya post.. he's 4 months, just a tad big for his age lol
he was in a shitty mood before, but for some reason loves drift dvd's and jap sliding on youporn i mean tube
i whacked on a street commo dvd a second ago (first one i could find) and he screamed the house down
so i whacked on drift central '' Luke fink go time'' and now hes laughin at the T.V, def my boy :)
Yes he is, nothing wrong with that though :banana:
Enjoy them whilst they're not moving though cause once they start moving their into EVERYTHING!! Haha such fun though :banana:
Yer mate, i can't run anymore boost then that atm cause im already running lean!
nasty
my old man has got that car; bought mr.pickles (auctions) personal car only 4000kms on the clock
pristine condition, had it over a yr now. TT powah!
nice car thats for sure, his retirement dream :)
yeah I love it.....has towed things and taken me places that my Prado couldn't handle.
Everything from towing a very large caravan to driving on the moon!
Check it out:
Lunar Surface
Small Martian in the background
Flat as!
One of the moon's craters.
Zero Gravity.
man, youd wanna have a good car to be out there, i find it bad enough driving my company car up
the freeway on a hot day :)
Not wrong Craig.
The locals were telling us that they don't bother recording temperatures that exceed 50 deg but temps in the mid 50's are quite common.....whew, I'm thirsty just thinking about it again!
All Skylines would die up there unfortunately.....and some 4WD's too, lol.
Nothing grows with that heat, not even weeds.
u might be able to change the springs inside the wastegate so u can run more boost, when i bought my turbosmart gate it came with 4 springs
running your gt3076 with the .7 compressor housing on your low mount manifold might have clearance problems with your engine mount
when i mounted my gt35 on my 6boost low mount manifold i had to have the engine mount machined down a bit to make it clear
whos gonna be at drift prac next saturday? as in, sliding..... not sitting on the stand with a hard on wishing
your car was finished.
I might actually go and enter. It's been awhile since I entered or even gone to watch.
Those manifolds were sold with in the HKS GT3037 kits which is the HKS version of a the GT3076 so he shouldn't have any trouble. you can see on the front 3 runners they curve up before the collector which allows for large compressor housing to clear.
EDIT!!
LOL that's not what you were saying though, the kits were bolt on items though so there shouldn't have to be any mount modification needed, from what i understand they actually move the turbo forward slightly from the factory position.
Edited by D_Stirls
Your apology is accepted and I appreciate that it was done publicly rather than by PM.
IMHO, it takes a real man to come out in public and apologize, so thanks.......water under the bridge now. :P
I'm sorry you're bold Pete :P Apology accepted? :teehee:
I know that of lot of people on here have arguments with their wives and girlfriends over the amount of time and $ spent on 'that bloody car'.
Valentines Day is approaching so I thought that I'd put forward this T-shirt as a gift suggestion:
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
