  • Replies 14.2k
see, its either channel 9's idea of "marketing" a show they stole off SBS and tryin to make it popular on their network, or the way of killing a show
i think its a poor attempt at advertising, which will end in the latter
just so you know matty, channel 9 now have the rights to top gear.
i know that craig
by "stole" i meant "bought with eddie's squillions only to put it in a shit timeslot and hope it fades away"
On a slightly different note
Lie Detector Test
Shame the court appearances don't happen before the election.......may sway a few of those old pensioners out there that think butter wouldn't melt in this bum's mouth.
anyone know if nisstune remaps can be REtuned?
yes, thats the whole point of putting nistune on there. a remap can be achieved by flashing over the eeprom of any ECU however the nistune actually lets you adjust each variable in real time..
troy, looks like shes giving head... which i suppose is why she has her name tattooed upside down (incase the one night stand is too drug munted to remember the name of the hussy going down on his unit... epic tattoo fail that
-D
    • and I thought size mattered 😝 At this point I may either pray to the Afterpay gods and get a torque wrench or attach a water bucket to the breaker bar. I appreciate the help though 🙏🏾
    • Or get a guy in his early fiftys to do it. A single good "oof" and about two cracks from his lower back is about the right tightness...
    • It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
    • Also, if anyone has a torque wrench around Williams Landing area and can lend it to me for like 5 mins - I got 4 bottles of Furphy left and I’ll throw that in with a Happy meal 😂
    • So today I decided to bleed my brake fluid, which meant to the wheels came off the car at my garage for the first time. I only had a 90cm breaker bar with me and I noticed that some 1 or 2 lug nuts were a bit hard to get loose (from when the shop did the coilovers) Now.... when it came to putting them back on, I didn't want to put all my weight and overtighten them. So I hand tightened as much as possible and then put normal pressure on the edge of the breaker bar and tightened it until I couldn't turn it anymore without putting in an effort. Do you think that is tight enough? Or is that still too tight?  They are tighter than finger tight. Last thing I want is to have them strip or warp sh*t. But hard times mean I can't just go down to Supercheap and get a torque wrench 🥺
