  • Replies 14.2k
haha yeah i suppose that is a point...
brings to mind that song by NWA "Just don't bite it"
-D
ive had a few moments where tattoo's like that would be handy. you dont wanna get her name wrong when youre in such a vulnerable position. lol.
ouch, PM's XI getting a touch up! Howard would have picked a better team...... I think if a few of us remembered that the new PM would need to pick a cricket team for tour matches, noone would have voted for Ruddy..
http://www.cricinfo.com/ausvwi09/engine/cu...tch/426302.html
hey guys i need some help BADLY, i have a 2000 nissan stagea with a neo 6 turbo, i have bought a turbotech manual boost controller and need fitting instructions, and exactly where to fit it as i have been told a couple of different things so far,in regards to the neo engine and its 2 stage boost set Up from factory.
so if anyone could help me it would be greatly appreciated.. because i am a little confused, cheers, i appreciate it heaps!
look up in the DIY section adam.....guess there would be a thread there about it mate.....but i am guessing it just goes in normally...one line for the actuator and another line from the IC piping
You need to unplug the two vac hoses that connect to the factory solenoid. That solenoid is what provides the dual stage boost in the neo's. If you stand over your bonnet, the solenoid should be next to the right hand strut tower, behind the airbox.
Creating a new helmet via CNC machining (ignore the different language). Aluminium Helmet
New see through tyres from Michelin.
New? tweels were announced years ago now ... Think it was announced in 2005 or so?
http://en.wikipedia.org/wiki/Tweel
http://www.gizmag.com/go/3603/
http://www.cbsnews.com/stories/2005/01/27/...ain669888.shtml
I stand corrected. :happy:
I knew I had seen these before but the article that was sent to me was dated late last year so I thought that they were a further development of the original ones. Apparently not. That's what I get for blindly accepting media reports without doing my own background check. :D
holy fuggin hell, this is one impressive workshop.
http://speedhunters.com/archive/2010/02/03...tory-part1.aspx
nice place but its missing some things,,,, a swim up bar with topless waitress
and a money tree in the corner for the pole dancers
otherwise it looks porno
ok cheers, once i take off the vac hoses do i need to unplug the electrical part of the solenoid or leave it connected.......stupid question hey, unplug it right....
The stock solenoid can stay plugged in. :happy:
leave everything plugged in as you are by passing the stock solenoid with the bleed valve :happy: wont be so in your face defectable item either
Who the Fu*k would do this.
Someone has walked into my front yard, gone to the garden hose, cut off the end with the connection and wheeled off like 10m of garden hose and cut it again.
What the..
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
