The Sa Wasteland
heslo
 Share
  • Replies 14.2k
Ive got a r32 wing to get rid of. 30bux in silver
Rubes - got the actuator ready for you. need to test the larger 18pound unit a bit later
will get it to you next week then.
ordered my 235/45 khumo ku36 tyres
also qfm a1rm 780degree track pads
sorted out front and rear braces, awaiting a seat rail for my seat.
also awaiting 4l surge tank & 305lph external fuel pump. comes with 5m braided fuel line
a cheap chip remap is on its way to me so I'll be piggybacking around the tune until I sort my shite out
trying to sort out the injectors, then will be ready to service and do all fluids.
in will go the roll cage to some extent, do a tune and she'll be ready.
sore-as atm, lol
$15 remap chip, lol
9000rpm, speed cut, boost cut, mapping
lol go ebay, like the $1.25 certified roll cage, $100 yellowjacket coilpacks, etc,
with my mapecu piggyback she should be good.
if not, meh. thought Id try tho.
wiring is all done, was lots and lots of spaghettio's of nothingness
found 2 on/off switches, about 10m of wires connected to nothing
everything is out tho, ready for the cage to go in.
No worries mate. I'm flying out to Sydney on Wednesday, not back until Sunday evening. No rush! :)
Then I got the actuator to fit, new intercooler piping to fit, A custom centre console to finish, and a turbo/boost leak to sort out all in one hit! :)
$15 remap chip, lol
does this mean your not going to buy my power fc??? =\
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
