The Sa Wasteland
heslo
 Share
  • Replies 14.2k
A teacher asks her class, 'If there are 5 birds sitting on a fence and you shoot one of them, how many will be left?'
She calls on little Ralphy.
He replies, 'None, they will all fly away with the first gunshot.'
The teacher replies,'The correct answer is 4, but I like your thinking...'
Then little RALPHY says,'I have a question for YOU.
There are 3 women sitting on a bench having ice cream:
One is delicately licking the sides of the triple scoop of ice cream.
The second is gobbling down the top and sucking the cone.
The third is biting off the top of the ice cream.
Which one is married?'
The teacher, blushing a great deal, replied, 'Well, I suppose the one that's gobbled down the top and sucked the cone.'
To which Little RALPHY Replied, 'The correct answer is 'the one with the wedding ring on,' but I Like your thinking.'
First thing i said to dave last night,
"those starcorps look alright..."
"they are not f**king starcorps, you douche"
lol.
they lack offset...
your meshies were much better!! IMO
they do? fronts sit a bit further out than the meshies did, rears despite being (apparently) a higher offset sit basically dead on where the meshies did. meshies were pretty awesomesauce though.
17 x 9 +unknown, mid teens, were sold as 18/19ish.
Starcorps
:P
stop it luke, you will make him cry.
im a big boy, i can handle myself... *sniff*
lol, i knew itd happen when i first saw them.
lol.
lol, your memory's a little off.
jake: (serious) "hey, are these starcorps?"
me: "am i the sorta person who'd buy rep wheels?"
is that Crozier st in Pt Adelaide Dave?
uhm... yes?
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
