Wont be going peddle box Matty, to much effort modifying the seat/gb leaver to fit it in.
Also will be having bracing through out the engine bay and underneath to help the chassis strength.
All fun tho, come out covered in black shit and seam sealer.
Get the HKS Kansai front strut brace, doesn't get any sturdier than that :D
  • Replies 14.2k
From painting the engine bay and hoping to have it ready for all jap day, that idea has been scrapped. Engine bay basically got painted then thought Fu*k it, lets take my time not rush it and do something crazzzzzzy.
+1 for taking your time and doing it propperly!!!
There will be more excitment leaving gtr owners behind :banana:
-1... would like to see you try :D
It's on fishy, end of year when the stroked 3L will be ready :banana:
Shotgun your RB26 Crank and maybe Pistons and Conrods.
race for pinks
Why lukes beast is Auto-matic. Its System-matic. Its Hyyyyydro-matic. Why, its Greased Lightning!
o wait its manual :(
Lol Dan
lol the 26 parts will be from the bottom end of the 26 he takes off when he sticks the 30 on.
yeah... prob the first time i've heard of someone parting out a 26 bottom end?? not like hes just replacing the crank etc in the 26 bottom end
yeah... and i was refering to dan =P
we was all refering to luke34. i refer to you as fishface :( untill it gets me a beating then i refer to you as the sob that hit me
affordable competition for mudhunter
http://www.carpoint.com.au/all-cars/dealer...1&silo=1011
Edited by Inline 6
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
