  • Replies 14.2k
quite possibly :stupid:
nice
sell off all you dont need, grab 2ndhand what you do need, and go for it
my 6700 r32 sedan rb26 has been reduced by around 1200 in parts sales
then added 3500 back into it to get it up to track-standard.
then less 5500 for bike sale. fun project
today i installed the braided front brake lines, front slotted rotors, and qfm a1rm track pads all round
hoping tomorrow my ju-36's arrive
here is the list from my car:
1993 Nissan Skyline GTs-T Rwd 4door grey sedan4 - $6700
RB30 5speed manual rebuilt gearbox with single button clutch
GTR RB26DETT engine with new rebuilt turbos
5Zigen 3" turbo back exhaust
Turbotech manual boost controller - $35
GTR intank fuel pump
Walbro 305LPH external fuel pump - $165
4 litre alloy fuel surge tank with 5m braided fuel lines - $265
550cc Siemens Injectors with new O-rings & seals - $350
Iridium spark plugs 0.75mm gap - $50
Yellow Jacket coil packs - $150
600x400x100mm fmic kit
Drift pod air filters
Oil filter relocation kit - $110
Oil cooler finned cylinder kit - $90
Ryco oil & fuel filter
Castrol Edge 6L oil
Fujimoto oil drain valve - $35
BHP roll cage - $5
Tomei 300kph GTS dash
AEM wideband kit - $250
Autometre boost gauge
Saas gear knob - $30
Saas steering wheel & boss kit - $170
Bride seat rail - $165
Gephardo race seat & 5-point harness - $200
Nismo ecu remap - $30
Map-ECU piggyback to stock ecu - $200
Car alarm - $35
Hood scoops - $25
GTR rear wing - $25
Tein suspension
Greddy strut tower brace & strut boot brace - $100
Nismo front tension rod link set
Slotted front disc rotors
Braided front brake lines - $80
QFM A1RM 780degree track brake pads - $235
17inch RJR Grafic mags
235/45/17 Khumo KU36 semi-slick tyres - $750
anything not listed means it was already on the car
i'll work it out and send u a pm mate
Awesome, gives me time to save up for a clutch etc.
Speaking of Clutches, i have made a choice of 3;
Xtreme Heavy Duty Clutch Kit $800
NPC 10" Heavy Duty Copper Mix Organic Kit $1093.50
ORC 409D-01N Kit $1399
What do people here suggest, or think?
NPC that will rate about 350 rwkw and its a great clutch
should be ceramic though ?? or did you ask for organic
also 10" is a pull type clutch do you have a pull type
I asked for a 95% street, 5% track type of clutch, and i drive an R33 GTST, so my guess is pull type. They say the clutch is good for 300rwkw and retains the factory feel.
i would get a ceramic Abe and just because its a R33 i wouldnt guess its pull most RB25 boxes are push but the GTR's have pull
your's being 1997 might be pull so don't know see if you can get it down to boostworx or another reputable workshop and get them to check it out
ive heard a lot of people praise and bag Jim Berry
they prolly say 300kw because its ceramic when i did the group buys the ceramic push clutches were 350kw and i sold them into 2x R33's this is why i say better check if its push or pull
push is a bit cheaper there push type Ceramic cushioned with 1200kg pressure plate rated for 350kw used to be about $656 << going from memory 2 years ago
see a lot of info in >>This Thread<<
note all links that say click are dead due to there website being upgraded
Abe - Jim Berry: Race Cluth, leave yourself a good hour and give him a call =) worth if for the info alone
Does he have email? I prefer to have things written down so i can reread and refer back to it.
a while ago they invented these things called pens and paper... some people find them useful, apparently jim is one of these people =P
just my hot tip, dont go for a soild centre cluth!!! :P
f**k luke, you can be a smart arsed flamin mongrel sometimes hey?
dont know if its just me, or my general tolerance being a bit lower of late, but that didnt seem to be a necessary comment to make. same as the mystery that you were trying to elude to in the domestic vs import dyno day thread.
grow up man, seriously
/rant
/rant
wtf is your problem?
english too dificult for you to understand??
i told him that jim doesnt use e-mail? how is that unnecessary??
and the mystery in the dyno day thread was a broken dyno!!! i don't exactally want to say "bosstworx dyno is broken, so dont go there"
think the only person here that needs to grow up is you!
/rant
Its not just you!
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
