The Sa Wasteland
heslo
 Share
  • Replies 14.2k
http://www.ausrotary.com/viewtopic.php?f=14&t=163249
epic hate thread about a dodgy seller
it gets interesting at page 2 :blink: here is an excerpt:
No proof of ever sending parts
Never any decent communication on 3 months + delay in sending out very basic order
100% total lies and bs to myself and my customer
Demands for removal of us posting on here as a last resort as every other normal avenue has been exhausted.
You never sent out the original parts, you f**ked Ben around for months you are a shoddy character who yesterday called my customer a "dumb aussie flamin mongrel" to me over the phone.
You are a piece of shit of the highest order@!
It took a mini van full of "dumb aussie flamin mongrels" to come visit (all the way from South Australia!) your dads house to get back their money from the failed turbo group buy where you were trying to back out and rip off poor people who trusted you and your bullshit!@
WARNING this is the same dodgy lebbo doing the same dodgy shit. My customer may have lost his money to you and I may have lost my nerves dealing with your shit "business" but believe me I will post this and I will encourage everyone who has been f**ked over by Omar Matter to post on every forum about this shady and down right dishonest dirt bag on every forum known to man that you post on !!! rotorgirl81, rx72c, any other dodgy user name you care to dream up and hide behind.
Give him his money back immediately or you will get another mini buss full of "dumb aussie flamin mongrels" paying your doctor dad a visit and informing him of the dodgy dealing you are trying to pull on honest people. I am sure he will be disgusted just like he was the first time learning about his sons dodgy dealings and needing to bail him out to save his face smashed in by a group of irate "dumb aussie flamin mongrels". Why you are allowed on this web site given the crap you caused over the group buy turbo thread is beyond me??? you and your crap "business" deserve a life ban from this place!!! I will make sure that happens to you if you don't give Ben his money back! & you will have to kiss my arse pretty hard to get me to remove any of these REAL AND FACTUAL EXPERIENCES THIS TIME !!!! :evil:
You have been warned and given every chance to fix this f**k up many times and many months over.
edit: u might have to be a member to read it
does anyone know how hard it is to hook up a turbosmart boost t?
wanna run about 9 pound, i wants more responce and alittle extra psi.
is it as easy as connect it then 1 click is 1 pound?
easy as but you will need a aftermarket boost gauge, they are fairly easy to install aswell. Be careful not to wind it in too much as it only needs quarter of a turn to get the boost you want. I did mine a few weeks ago and went to pelican point rd where there are no cars and set it to 10 psi. There's also a diy thread on here somewhere just do a search.
the cop raid was around the corner from my place, couple hundred meters..
from what ive been hearing, i went to primary school with the guys theyre targetting. :)
Yerp same here, we can throw rocks at the back of his house from our front yard...went to the gym and the cops were raiding his place didn't realise what for until we saw the news that night
Bikies vs Street Thugs
Sapol would be loving it. They'll sit back with their popcorn and let them wear each other out and pounce at an opportune time... tho tbh I think the bikie conglomerate will anhiliate the new boys lols
-D
Well the bomb was intended for a New Boys guy which lives like 25 metres away.... he'd be shitting himself and if he was smart be moving away from that house before another attempt is to be made!
who knows eh.
the two they sent to do the job were obvious candidates for the darwin awards. lets hope they didnt have any offspring
0% sympathy.
-D
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
