The Sa Wasteland
heslo
 Share
well since everyone else is saying they know the guy i thought i would say something too
i shared a shed with that blue sil80 at aq drift day last year i think and talked to the owner which i guess might have been you?
wow i feel so popular :blink:
i remember you man... it was great chatting that day.. hopefully we can say hi at another drift prac soon :cool:
- craig
  • Replies 14.2k
anyone know if 34 GTR castor arms fit GTST ?
they look like the same dimensions but GTR ones have a kink in them for more/less castor and i cant seem to get the front bit to bolt in
Than I would have to say no at a guess
they look identical to stock ones , but who knows with my car.
ill try get some stock GTST one's to compare
nismo castor rods have the same part no. for S14/15, R33/34 RWD, so I'd be guessing that GTR rods are different Mitch
I have a set of stock ones with rooted bushes if you need to compare
Be a cool Step Daddy and build the kid a SLED!!
You know what? ... I typed that, read if afterwards and wondered how long it would take you. :yes:
I'm sure Cam would like something that can go around corners tho Pete :D
Got a 100cc go kart coming for the little lad. Its a project for the two of us to rip it down and rebuild it so he can get into some kart racing ... and I'll get the odd ride in it. :thumbsup:
Here is a wasted engine for the Wasteland ...
Pulled the engine apart from the race bike today. It shows one cylinder gone off like a grenade. :yes:
Clothes off, engine out ...
What was left of the conrod punched a hole in the engine casing ...
Crank is also rooted ...
The barrel was destroyed ...
And this is the piston !!!
:thumbsup:
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
