Well, Ive driven the R32 2 nights this week. The first night it got vandalised, and tonight I hit a stupid animal and snapped the drivers side mount on my front bumper, so its sticking out from the guard :blush:
anyway, Wayne, here is my old daily. 1989 Mazda 626.
If you missed the intercooler hiding behind the front bumper, and the 95db exhaust, you'd also miss that it had more power than some of the Skylines on this forum :P . Shoulda kept it, would have made an awesome track hack
  • Replies 14.2k
Well, Ive driven the R32 2 nights this week. The first night it got vandalised, and tonight I hit a stupid animal and snapped the drivers side mount on my front bumper, so its sticking out from the guard :D
If you missed the intercooler hiding behind the front bumper, and the 95db exhaust, you'd also miss that it had more power than some of the Skylines on this forum :) . Shoulda kept it, would have made an awesome track hack
I notice that car has a Black & White Cat.
Sooo glad its friday! bin a busy week! tires are going on tomorrow so wheels will be back on :D
i hear that lewis......we had the network down for the last 2 weeks....been so damn frustrating lol
seems my friday is going extra slow today. Alot of driving, and not enough work. Trying to find a present for my 2yo Niece, organise a car trailer to move the drift car tomorrow, and organise some new private health insurance.
is it beer o'clock yet?
Sooooooooooooo how is everyones Friday?
Crap and Boring...Slow also, hardly any customers, there is only so many times you can walk round the store looking for things to do, luckily we have a PC with a TV Tuner in it, so i am watching the Olympics.
Does anyone know when the Drifting is on? As last week, i swear i saw some on around 4pm, just cant remember which day it was or what channel - Hardly watch TV, mostly download episode off the net.
^ we used to go to the dog and duck for beers straight after work - i still pop in every now and then for a pint. Theyve got a good selection of beers Wouldnt bother hanging there any later than 8pm though
Richmond upstairs Friday after work sessions ftw!
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
