  • Replies 14.2k
got really tired of hearing the ford vs holden bs there, its the same friggen car with different headlights and tail lights. quit telling me how sh*t 1 is compared to the other. and those utes were slow as f**k, funny how they still manage to loose control all the time though
i was thinking the random talent was better than the promo chicks.
Edited by Inline 6
you obvioulsy no sfa all about the utes then.
I hear you neck becomes slightly more red every time you drive 1 :( im sure they are the coolest out in the stix.
taken from their webpage "The Ute's are production based, and with limited modifications" i was under the impression they just had exhausts and maybe a brake upgrade.
Edited by Inline 6
to be honest i dont think i actually saw any of the promo girls while i was there....strange.
:(:O:O:O sooo in love with this car right now lol
Didnt he have engine dramas on saturday......me thinks not so reliable ride that one lol....
Dan as far as i knew the utes were production utes with very very limited modifications.....hence why they only do 8-10lap races and not like the supercars which does 70+ laps........never been a big fan of the utes.....
they not that bad when they start smashing :(
the minis had quicker lap times though :O they was tuff minis though
what would be entertaining is 1 of those time attack sessions like the malala sessions. kier wilsons 32 and revs rx7 n such but im sure they wouldnt like some non holden/ford stickered car beating there lap times.
Edited by Inline 6
As much as I like 32's I would be morethen happy to pick something newer over something that's older.
If for some reason I make some decent enough money on the rigs I'll be looking at evos and f6's (Ba, Bf)
I like newer car :thumbsup:
32's and 33's might be getting a bit old but still has modern technology behind it....look after it and it will look after you
how hard is it to change the harmonic balancer on a RB25???? *looks at dale*
I would love an f6 or a maloo ute over a skyline other then a 34 or 35 gtr
such nice cars inside and out plus power
Each to their own. I personally wouldn't touch anything domestic and if I had to it'd be a Aurion/380 or Magna
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
