i have no words to describe the stuff found in this thread...
http://forums.overclockers.com.au/showthread.php?t=860659
im not sure if i should laugh at the stupidity, or be appalled at the sheer amount of bigots....
the whole site is unbelievable
  • Replies 14.2k
Hey Chad,
what offsets are you running on your Stagea, and what size tyres. I'm putting on GTSt brakes and need some spacers so I may as well fill the guards out while i'm at it.
The rims I have at the moment are bogan/bob-jane spec +38 18x235s I'm thinking 25-30mm spacers front, maybe 15mm rear or just leave it as they are.
19x8 +30 on the front with 30mm spacers with 235 tyre and they rub on the guards so could do with a 25mm spacer instead. Rear are 19x9 +30 with 235's and they fit sweet.
what are your thoughts on these:
330mm with brackets,
Slotted & Ventilated
Dynamic Balanced
Heat Treated *Surface Coated
Heat resistance up to 900 degree.
$595 on trademe.
or here: http://www.conceptzperformance.com/Cart/de...29118.210.8.101
326mm with brackets, $430usd + postage
also arranging:
hks 87mm pistons & attkd h-beam conrods
acl race main & conrod bearings
ati 600hp harmonic balancer
rb26 clear cam timing cover
apexi multichecker
hks step-2 valve springs
hks oil pump
$3000 delivered. woot. double woot
I have been reading some of the Landover Baptist stuff Carl .... freaking hilarious ;) .... some of the appalled reactions to what is clearly a joke site are off the dial hilarious. Love this one in particular:
http://www.landoverbaptist.net/showthread.php?t=27676
try not to get cross drilled rotors Brendan they're more likely to crack
My GT-R rotors have tiny little hairline cracks 1 - 2mm long coming from the cross drilled holes,
very shortly I'll be looking for some slotted rotors, along with a brakefluid flush
Edited by Weezy
What happened to race car on a budget brandan? I mean its good if you can get these parts cheap but the costs are going to take you on a roller coaster and before you know it you've spent way more then you had intended lol
it has to be the biggest troll in the history of the internet. the size of the forum is amazing hey
yeh this is for down the track - auto awd rb26 stagea ;)
the sale of parts from the r32 sedan and my current engine will suffice
ie: rb25 ported head, tomei camshafts & valve springs - $2000
rb25 gt3076 garret ball bearing turbo - $1500
rb25 bottom complete bottom end with rwd gtr sump - $500,
rb30 manual box, tein r32 suspension, injectors, splitfires, - $2000
gtr fuel pump, stagea brakes, gtr front calipers, Panoz racing 4-pot billet calipers - $1000
gtst sedan shell, other bits etc, a few more grand easy.
fkn Chinese shit!
took the gate off this arvo, yep, was stuck open, taped it with a hammer, put it back together and back on,
started it up and woooot, i had boost again! gave it a good hard rev after it warmed up, and bah! prick of a thing stayed open.
ahh well, def in the market for a new gate soonish.
<3 the flutterz thru stainless intake pipe tho ;)
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
