  • Replies 14.2k
5stud, 2-pot single-sided fronts, 1-pot rear's
fixed a leak at the caliper (thru the bloody thing, nuts that keep the caliper together wernt tight enough)
the dust guard seems to be making some noise, something....... unless it's the pads against the rotors
yeah, should be able to boof, i got a set of R31 rears on order from DBA as "blanks" as i need them drilled for 5 stud. costs a small amount more as they have to pull them off the run n that, but ya should be able to
Anyone able to help me out? Need someone to go to JIS, buy me some R33 Tie Rod Ends - $175, and meet me somewhere, ie vilis, and i shall pay you back. I need the suckers in my hand by Saturday morning. If you are able to help out, send my mobile an sms on 0411876139 with your name and number and i shall call you back.
Edit: If they aren't in my hands by Saturday Morning, i will most likely be unable to attend the track day...there is also $50 in it for who ever does collect them for me.
Thank you to Madaz and Ruby for sending me a sms about picking these up. I managed to speak to JIS today, and he said he was going to be there till about 6-7pm, so i managed to pick them up :( . Also had a little chat, looks like a few of our forum members are regulars there *looks at Andrew and Dave* :thumbsup:
Hrmmm seems i could be stuck with going non turbo 33 rotors...Can you buy rotors that haven't been drilled at all?
could just get Growley custom machining to redrill 5 stud to suit 4 stud i had him do that for me before i had a 5 stud conversion and no troubles
http://www.growly.com.au/
npz Abe good to hear your sorted
Yeah Dave and I practically live there. If I could have gotten to Vili's tomorrow night to give them to you I would have picked them up for you. I live less than 2km from JIS, so pop in to see Koji and Paul frequently :P
So many toys, so little money - there are always things there I want.
i have some rotors with matt atm getting redrilled from hq patteren to ford pattern for the race car he can cross drill or put a few different grooves for a pretty good price .
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
