  • Replies 14.2k
They're that bad are they? I've heard good and bad about them, was thinking I'd try them out myself but seeing they're close, ah wells.
yes they are. Should of gone around the corner to Edwardstown custom body reapais or even more south to hounslow crash :ninja:
well your just silly then.
Why pay $30,000 for a parts kit that you can do in Australia for $50.
RIPS are pulling over 10,000 rpm on burn out and 1400HP on a standard RB30 block with standard crank and crank girdle.
Edited by D_Stirls
ugh. gtr purists. im siding with dale. f**k spending $30k on some liners and a bolt on deck when i can jump on the club and find a 30e bottom end for less than $50.
and ive heard of quite a few of the os kits failing at life. id be pretty torn up about $30k going to waste, but i wouldnt give 2 shits about a 50 buck bottom end.
*just had a look at the kaki kit, seems waaaaay too cheap.
makes the perfectly nice car look a little cheapish and nasty / track hack job imo.
and i could 'almost dig it'. the splits a little off. if it was something like this,
itd be rad, and i actually would dig it.
Think I should of called before I went for a drive, went all the way to MC Doyles Crash Repairs and they were closed... as in like they didnt pay their bills and got shut down. Guess I'll have to take my business elsewhere...
that really isnt a bad thing.
Edited by scandyflick
that Kaki* kit is only sleeves and a block deck so no $1500 is not that cheap
Dan its about 450-600 to get an AWD adapter plate for the RB30 but a deck is a stronger better RTA friendly option you keep your original engine number
No pos RB30 bottom ends should be in a GT-R imo
Dont get me wrong, I'm all for twin cam RB30's in VLT's, GTSTs, etc but not a GT-R... C'mon lol
Putting an rb26/30 in a gtr isnt a bad idea, if you use the car for performance or any kind of motorsport
keep the 26 stock tho if you want a streeter that'll hold its value - if I had two gtr's, I'd def put a 26/30 in the 2nd one
-D
This is actually a blessing for you. PM me if you want further info but I wouldn't send my worst enemy there...
And I'm a big GTR fan but nothing wrong with a 26/30. Shit, I'd build one would it be not for the legality issues and all. Don't fancy ripping out a motor to visit Regency
Word
-D
with all this talk of rb30's, im feeling good, just a cam, turbo..and a manual conversion away!
Also, whoever owns a 100 series Landcruiser...you sir or madam, know how to select a good car!
Definatly the best 4x4 ive driven, and the easiest to work on. :)
would it really be noticeable to the untrained eye though? (having a 26/30)
Easily. The RB30 block causes the head to be situated very high compared to the stock 26, pm cubes and ask him about how much clearance he actually has (he reckons its not a lot)... cant run a strut brace with a 26/30 unfortunately
-D
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
