  • Replies 14.2k
Nice new Avatar Cara :)
I got my car back today, was the manifold turbo gasket that had blown out, the bolts had stretched a little and exhaust began to escape, if i had tightened them up as soon as i heard it i wouldn't of had to replace the gaskets. So $280 later they are replaced with genuine nissan gaskets, and a bag with what was left of said old gaskets.
wont let me submit the online form ruby.. so ill have to get a copy off damo and fill it in..
Craig had the same problem. Damn online crap :D PM me your details (name, addy, phone etc) and I'll sign you up. Do you have the bank details? I'll PM those to you too if not.
Thats not too bad really. I pulled apart mine on the weekend and found $700 worth of things to replace (on top of what I already had known about), thats parts with me doing the labour. :D
Thats not too bad really. I pulled apart mine on the weekend and found $700 worth of things to replace (on top of what I already had known about), thats parts with me doing the labour. :)
Yeah, i could have saved myself about $200 by doing the work myself...but i wouldn't have trusted my workmanship in doing it. Sure it probably isn't that hard to do, just more time consuming then anything, plus he found the tie rod ends not installed correctly, and also replaced the hose clamps on my power steering to try and stop it from leaking.
just got my detailed tax invoice from garage 7
.........all 3 pages lol
I got a 3 page invoice from Tilbrooks in my little car file. I bet you can imagine how not cheap that was, pretty sure the labour it self came to 4k :)
Money well spent i recon. Car has been pushed very hard at the track many many times and the engine is still going strong, same can not be said for many other Rb26 powered cars.
this is true. ive spent much on labour at my preferred mechanics (see below) because each time i tell em to do something, they do it.
woot
-D
Spot on, 26's are great provided you do things right... the FIRST TIME
thats good to hear chad, would suck a fair bit if you had spent alot of money for things to go wrong all the time....
Matty T who's doing your cage?
Lance quoted me 2200 for a full weld in then a couple of hundred extra to have the cage go through the fire wall to the strut towers which im defiantly doing, so around 2500 for a full weld in, which i thought was cheap :(
Earliest they can do it is July :).
hrm, carl williams bashed to death on the day the media revealed his daughter is getting private school fees paid by vic police
my guess is he ratted someone out in exchange for the cash and the inmates put 2+2 together
ahh fun stuff. who needs reality tv when u have reality to keep u entertained? heh
-D
Looking more likely
http://www.smh.com.au/national/as-the-rumo...tml?autostart=1
"Police will investigate if one of those rumours - that Williams had abandoned the code of silence and become a police informer - was the reason he was fatally bashed yesterday inside the maximum security Barwon Prison." and
"Rumours have been circulating in the underworld for nearly 12 months Williams was trying to cut a deal where he would give evidence in major cases in return for a substantial reduction in his crushing jail term."
and Cronic you were spot on too, apparently it was a 'friend' who did it....
-D
Ben, the guy was a murdering weasel that got others to do his dirty work for him.
Can't believe the amount of peeps on other forums that are saying RIP, like he's a hero or something.........Mother Theresa didn't get this sort of attention, lol.
Just hope he made his peace with the big fella in the sky before biting the bullett.
do iiiiit. dont make me finish mine before you :(
random question, who's reputable to send rocker covers to for painting?
Paint them yourself Matty, I did my 31 covers 8 years ago with bright red VHT paint and they still look show room fresh.
and if your keen on some airbrushing flames or ? then pm me I might be able to hook you up
just make sure the rocker cover is spotless outside and a light scuff with a scotchbright, the logo if its has one can be removed and polished up or ?
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
