  • Replies 14.2k
Car is booked into Walker Chassis for July :blink:
Full weld in cage, Heaps of bars, strut tower bracing, the whole lot ;)
Got my welder mate coming down in the next couple of weeks to do seam welding, drop tank mounts and covering up the backseat from the boot ;)
looking at doing tarmac rally at any stage in the future luke? if so i advise that you get the sill bars done now, otherwise they're a flamin mongrel to get in later on. thats why mine's getting them now and when i need the additional bracing to comply with tarmac rally regulations, its partially done
yep sure is ;) one of the first things i did to it, just gotta have the cooler piped up, boost turned up and a nisstune board and im basically done.... for now
And you said you'd leave it standard! :blink:
Cheers mate, I'll add that to the list. Lance was also telling me about A-pillars bars if i should get them or not, he was saying it becomes a bitch to get in and out of the car tho.
Got any pics what the sill bars are?
Damm ppl posting before i hit reply, this msg is for matty t.
Edited by Luke_ENR34
please sir tell me more
the sill bars are essentially a bar that runs along the floor pan front to rear..............basically going to protect from random trees that may jump out in front of you. i'll try and find a diagram in the CAMS handbook
Hmmm wheel swap maybe :(
Don't swap to another of the 'emotion' series man - The XD9's suit your car to a T. Unless your going some like TEs - LMGT4s - or vlk GT-C's or something it won't look half as good as it does now!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
