  • Replies 14.2k
hahahah yeah Krishy wish he would tell us where his money tree is :(
Nice one Mark
i cant believe there allowed to sell these perfect attire for the gang of 49
do they have sewn in weapons pockets, and car thief gear liners inside
and where do the petrol sniff cans fit..lol
This should be the last bit to get the car rolling. Only thing I need now is to borrow some r34gtt/gtr shocks/springs then when I save up some more Ill go on thr hunt for some ohlins with remote oil canisters.
Then come brakes and dog box :(
cant wait to see that thing back on the road lukey.....get a hollinger box if you can :(
Then come brakes and dog box :P
you inspire me to be a better person :P:rofl:
so what would be the best way to go about the the headgasket issue and if it is a cracked head how would i go about that?
cheers for your help
pull it apart yourself taking plenty of photos along the way so its not too difficult to put back together. take the head to an engine place (i have used richardsons engine service, but ask around there are plenty of good places). get them to check it over and face it.... if its not warped/cracked slap it back on and do a skid. if it is munted depending on wether you are going to do the labor yourself suss out quotes on a 2nd hand motor vs new head
btw its a good chance to replace hoses when the head is off
going to renmark on wednesday, to check out a 50acre property
a third of the land is producing fresh produce with a contract for harvesting/sale
has plant equipment and monitered irrigation, tractor & all the parts needed, 4wbike
nice roomy house as well, spare bedroom for parents/visitors to come up & stay every month
might do it. make a go of it while my knees are out.
got say 12-15years from hereonin until I can get knee replacements (due to age & the nature of my knees),
plus thats how long the kids would take to finish high school. 2010-2025 we might be farmers in renmark.
come back to adelaide once kids are ready for Uni - plus the crop yeild will be its best in the next dozen years.
otherwise im stuck on disability pension doing nothing, getting nowhere
this could set us up a little, ie your house/land is your business/income, enough so that we come back to adelaide in a bakers' dozen years
with cash outright for a nice home, R35 or R36, get the knees replaced and see where we are at
kids at uni making their own way, and by then I may be totally rooted with the knees, but at least give it a go
could be win
good luck tangles i hope it all works out for you up there, ive just moved back to adelaide from up there....but only cause the riverland wasnt too kind too me :rofl:
but i hope if you do it that everything goes well for you :P
cheers, we'll see on wednesday & go over the fine details
it brings in decent income over 24months, dont know costs yet, no water license so thats a downer
price-wise tho we'd start afresh and make a go of it. its not beyond us, just the unknowns . . . .
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
