Whilst we are here....
btw, do everyone else a favour and do not post up the answer.
ARE YOU IN THE TOP 2% OF INTELLIGENT PEOPLE IN THE WORLD? SOLVE THE RIDDLE AND FIND OUT.
There are no tricks, just pure logic, so good luck and don't give up.
1. In a street there are five houses, painted five different colours.
2. In each house lives a person of different nationality
3. These five homeowners each drink a different kind of beverage, smoke different brand of cigar and keep a different pet.
THE QUESTION: WHO OWNS THE FISH?
HINTS
1. The Brit lives in a red house.
2. The Swede keeps dogs as pets.
3. The Dane drinks tea.
4. The Green house is next to, and on the left of the White house.
5. The owner of the Green house drinks coffee.
6. The person who smokes Pall Mall rears birds.
7. The owner of the Yellow house smokes Dunhill.
8. The man living in the centre house drinks milk.
9. The Norwegian lives in the first house.
10. The man who smokes Blends lives next to the one who keeps cats.
11. The man who keeps horses lives next to the man who smokes Dunhill.
12. The man who smokes Blue Master drinks beer.
13. The German smokes Prince.
14. The Norwegian lives next to the blue house.
15. The man who smokes Blends has a neighbour who drinks water.
  • Replies 14.2k
Well I have been thinking about whats next...
2000 model R34GT-T
2001 200 SX
2001 Silvia
2002 WRX or possibly an EVO
So in other words im pretty undecided! I just want something a bit newer then what I had. I find it hard to justify paying an extra 7k to buy the same as what I had, but turbo.
http://www.carsales.com.au/all-cars/privat...VO&trecs=18
This looks decent.
I dont know heaps about Evos but I can always learn.
That looks really really nice, massive fan!
Despite needing a decent buff lol.
I agree with you in that, if you sell a car to move on all together, spending another 7k for a GTT is a bit meh.
When I sell up on the 32-R I'll probably go something totally different again and go rotor. Brap brap brap :P
Edited by Weezy
This looks decent.
Honestly if you want an evo, get Iron Chef to bring one over for you. Hes had some evo8s up for near on $20k del.
I'm not sure how the import process works in detail but it does seem like a pretty lengthy wait with a bit of risk attached to it. Not sure how the bank would like it either... (I'm going to have the cash from my car but im going to the bank for the full amount (to get low interest) then chucking my $ on the loan after.
I did speak with the guys at Pitlane briefly about importing, the prices were pretty decent!
That one was an exception to the rule :P Nice Evo 7s can be had around the $21-22K mark though. Awesome car for the money.
And totally OT - JMW... CHOCO-BANANA!!
Nice, some guy did want to do a swap for an RX8 but he wanted 27k and im not spending that much!
"Evil is simply the absence of God. It is just like darkness and cold, a word that man has created to describe the absence of God."
There are many flaws in that argument Steve, but surely even you recognise that 'God' is a word that men (as it probably wasn't women) created to describe events that they couldn't understand. For the above statement to hold true God would have to be measurable like light and heat.
Also you can watch evolution at work by studying a virus (although there is some debate as to whether viruses can be considered a form of life or something that exists at the edge of life).
Is that a personal loan or car loan i was pretty sure most banks wont touch imports with car loans but a lancer they might be happy with
Edit the evidence of God is signs and wonder's commonly called miracles, but that requires faith.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
