  • Replies 14.2k
gettin pretty desperate for stock 33 gtr suspension....can anyone point me in the right direction ? Need to borrow it just for an ID inspection (and yes posted it up in the "wanted to borrow" thread, with no luck..)
Hitup Sinergy Motorsport - See if they will lend you a set and or go into Japanese Import Spares - from memory they do hire out items too. Of course, you break it you buy it haha
around 4 months ago; we had to twist koji's arm to lend us a part for 24 hours. Put some dollars under his nose for them to hold on to and he ended up letting us have it, but he was reluctant to as he didnt want to get in strife from his manager
may have a different system in place now though
Pre sale is Friday to Monday on ticketek website.
You need to be a member of ticketek which is free to do online.
They went on sale at 12 noon today and the servers were flooded. Finally got through and at 12:30 gold seating was only in singles and silver seating had to be refreshed about 20 times before they let me go through but standing was all good.
$150 a ticket though but will be very worth it!!
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
