  • Replies 14.2k
Hey guys, my A/C seems to be pretty gutless (not that I use it much but anyway) so I was hoping to get it checked out and regassed if necessary. Who's the best person to speak to in that regard?
Thanks in advance.
strange problem
my right indicator has been playing up the past few days, the speed in which it flashes changes.... sometimes its going flat out and sometimes it going normal speed.... when its going flat out the front light outside doesnt work but the side and rear does... but when its at normal speed the front one works too...
the left side is fine
any suggestions as to what the problem is?
strange problem
the globe is probably loose and when the car hits bumps it moves around.
strange problem
I've got the same problem. Either what Chad said, or a bad earth.
Resistance.
If you have one globe that is out..it causes the rest of the indicators connected to that line to blink faster due to less resistance.
Make sure all your globes are the right watt, and you should be ok.
Feel free to correct me though.
Yeah - if you have a dead indicator bulb - your other indicators will blink more rapidly.
Definitely sounds like a dodgy bulb (filament could be loose or on the way out), or some sort of dodgy connection (earth/etc).
I'd probably start by changing the bulb and seeing if that fixes it...
i would just like to vent my anger and frustration towards Optus Optoss
their SHIT HOUSE network seems to not allow some calls into my Phone ...
and i found this out via email from a company i applied with
this raises the question , how many calls regarding jobs have i not been receiving?
after working for optus for 5 years , i am glad i no longer work for them
this is a JOKE !
my phone doesn't even ring , or get txt messages saying i have a missed call...
and this is my 3rd iPhone...
stupid POS
I've heard plenty of bad feedback regarding optus lately, with a variety of their services- mobile, adsl, mobile internet - they seem to have gone a little downhill from what I hear
but with the other equivalent competitiors - vodafone, 3, etc; they're all just as bad as eachother.
Telstra is the most reliable for coverage and services, but they're still a pack of *****.
thats why im going to get a $59 pre paid when i have the money to do so
just need something thats going to actually receive calls !
This.
Although sometimes I have trouble with not receiving msg/calls too, but that could be the cheap as all fk ($50 outright - brand new) phone I've got :D
ive got optus as my moblie wireless internet and my house phone. THEY SUCK COCK!
they are pricks! i was meant to be put on a plan that was signed for that was just a cheap $50 a month which included house phone and my internet.
i got my first bill (not including connection fee's etc) that was 120 for the month and i didnt even use all my downloads!
call up some indan that i couldnt even understand and they said that the contract i signed has run out the day after i signed it so they put me on the next service they had which is shitter then the one i signed up for and cost more.
alot of abusing to optus and i got the price knocked down to $70 a month but on their contract small print says they can do what their doing some how. dont have the time to deal with them anymore!
telecomm omnibudsmen , they fixed up my phone,bill with op'tard 3G
I still use them but I now have better service levels and my 3rd free unlocked phone, Iphone
but like some of you noticed the service the past few days has sucks donkey balls, 1 or 2 bars in town and the random no ring but missed calls
and your sadly mistaken if you think Telstra will fix your problems, my work phone was just as bad if not worse
Australia gets farked when it comes to cell phone bills, in USA unlimited calls is dirt cheap
they all suck..lol
they all suck..lol
Ive noticed at my house usually I have 5 bars of Optus 3G on my iPhone, but today and yesterday sometimes its only running in 2G (the little circle) or 3G with 1 or 2 bars. WTF!
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
