  • Replies 14.2k
i knnow fitting restictors and doing internal mods but shaun said not to worry unless your rebuilding..
i have mines cam baffles and 26 covers which will help..
all built engines i have read in the FI have had this mod done!
What are you doing it for? I have a 26 which are bad for oil problems and i wouldn't even bother with one.
coz mines gonna see some limiter loving come june 19th drift prac!
and im just making a $200 sacrifice to save my engine..
i did read that unless u have a aftermarket oil pump u dont really need to do the external oil drain..
the baffles should be fine with a catch can setup..
Just fill the oil up to the top of the H on the dipstick, That's how i keep my RB's alive on the track.
and its worked so far
from what i saw it wasn't easy track time either and what maybe 8 laps with some drifting on the SAU|sa track day
In other news, "Lost" sucks a fat dick and I'm glad it's over, that ending was... was... there are no words
OOOooooh don't spoil it - I'm just about to finally get around to watching it (just watched the 1 hour 6 season-spanning re-cap episode) ..
Gah! Now I'm stressing that I've wasted the time watching 6 seasons of a tv show :cheers:
I personally thought it was a piece of shit but you're experience may be different. Let me just say this, a certain main plot point in season 6 was TOTALLY useless, the last few minutes of the show totally wipe it out. That and the "ending" was something the creators said from day one would never be the ending
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
