  • Replies 14.2k
Think I will getting a letter from customs either tomorrow or early next week about some parts I got coming in.
Been 1week already in customs awaiting approvel to send out to me. Should be 4-7days delivered instead.
Heard a few interesting theories about what they want to do to fix it up.
This BP thing is just silly, surely with the amount of off-shore drilling going on these days, you would have a plan to stop this yeah? WRONG!
I say just sikaflex that shit.
It's not just BP you know?
It's the company that owns the rig and the company that concreted the base. All of them are at fault yet the media only play up on the big name. There's also a chance this could be the end of BP as their stock prices have dropped dramaticlly so only time will tell.
The reason why it's taking so long to fix is because they have to deviate a new well from a few km away to force the mud through the original well that they tapped into. They will have to re sleeve the old well which is going to be hard work as the psi is so high from the escaping gas which is forcing the oil out.
The mud that they are using has some chemical base which doesn't allow gases to go through it. This will slow the oil flow till it's eventually stopped and then use the new well drilled to continue with the remaining oil.
so, i have been hammering my car loan to get it out of the way
i have $77 left,
if i pay that $77 right now, i have to pay a $300 fee to close the loan early.
FFFUUUUUUUUUUUUUUUUUUUUUUUUUUU BANK SA!
thats the case with every loan Craig! It sucks.
That's why (depending on the purpose) I'll use a credit card with 12mths interest free terms. Zero interest and I can pay it out in less than 12 months with no BS payout fee.
:blink:
^ thats the same with my loan, the fixed interest one anyway.
Also seen your trackie at Garage 7 today Craig, looks tough as a badly cooked steak with the wheels spaced out.
would have seen my black coupe there too!
:blink:
If you can afford to pay out a 15k+ loan in 12 months, a $300 fee isnt much to worry about!
i have $77 left,
Savings&Loans offered me a no early exit fee loan :blink:
lol, cheers man, i gotta find some 27mm for the fronts to sit like the rears..will have to get wheelworx to make them..
were the boys working on it?
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
