  • Replies 14.2k
Well. My poor R32 has developed a driveline problem. It seems the clutch wont disengage the gearbox fully. I drove down half of my street in 2nd gear with foot on the clutch. It crunches 90% of gearchanges, and to put it in 1st the car needs to be switched off, select gear, then start again. When you take off it shudders and makes a clunking sound. Been talking to Dave and he has suggested checking out the clutch fork, slave, and pivot.
Have you bled clutch correctly? Do it on a hoist (like I did) so you can see the amount of fork travel at the slave cylinder. And bleed it from ALL bled valves. My Stagea has 3.
:thumbsup:
I did bleed the clutch, albeit on axle stands, and it all seemed to be doing its job. I will have a look if I get time, but Ive got an appointment, need to finish a uni assignment thats due today and work. Cheers guys.
blokes just throwing it out there small cruise happening sat night at bunnings parafield 7pm just carpark to carpark deal anyones welcome should be a majority xr6t's but we get 1 or 3 skylines rock up so if u want a fair quick paced run sat night cum down and talk shit and say hi
Alot of SA people are going to the Kadina Show and Shine this weekend, so you might not get much of a response. And maybe dont include the meet location, unless you want unwanted visitors, and i dont just mean cops! :thumbsup:
easiest way to bleed nissan clutches is to have 4 hours and plenty of beer spare, or buy a 1pc braided line from master to slave and p1ss the balance block and damper pipe off. Most good workshops will follow the factory service manual and pressure bleed it with a vacuum device :thumbsup:
I had a similar issue, didn't crunch gears but was sticky as f**k. Clutch fork had spun on the thrust bearing and the slave was pushing the fork on an angle etc etc, it was really messy. It was all replaced before any serious dramas but frusterated the f**k out of me.
Quick Q:
Whats the main differences/advantage between R32 GTST front calipers and R33 GTST front calipers?
Is it simply the 32 is just for 280mm rotors and 33 is just for 297mm rotors. Any differences in piston sizes?
so found our new puppy after looking for a good month, bullmastiff x staffy.
only thing is, its in pt lincoln god dammit.
looks like im going for a drive next weekend
Congrats! Looks like a beautiful puppy. Please make sure you train and exercise it properly and love it dearly.
hahaha mastiff's get huge staffy is a medium dog
personally i wouldn't buy cross that's when you get temperament problems
Sorry Steve but I'm going to call bullshit on that statement.
I have volunteered at the Lonsdale RSPCA in the boarding section for over 18 months now where we have a minimum of 70 dogs every day and up to 120/130 dogs per day on long weekends. After looking after, walking, playing with, feeding and grooming 1000s of dogs I can tell you that temperament problems have nothing to do with cross breeding.
Dogs are the most loving and loyal creatures (to humans) on the planet. Temperament problems that can occur will usually be due to the humans that come in contact with the dog, its surroundings and everyday life, if the dog has been attacked before, or in some cases mental illness (just like humans have).
As someone who studied genetics I can tell you that 'pure bred' dogs have suffered from generations of in-breeding, usually grandfather & granddaughter mating, and IIRC in some breeds there are less than 50 variances in their genetic code, ie they are closer to extinction than the Panda Bear. I will need to search to provide a reference for that statement though. Cross breeds vary the genetics of the dog and are therefore likely to live longer and suffer less illness. I had all this info on my old C: drive which died so I'll have to search for the books again to elaborate further.
FYI
****WANTING TO BORROW****
Pair of NON-HID R34 headlight for regency, will swap my hid's for yours standard ones and when im off defect then swap them back and sure i can find a 6pack in it for you too.
Please get to back to me asap as regency is booked for the 22nd of june and my original headlight plan fell though
-lewis
0432 581 798
Mitch there should be something under the car, basically alittle toggle thing which u need to undo.
And Lewis I got non Xenon ones here u can borrow.
Edited by Luke_ENR34
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
