f**k the spectators !
when your on the track you forget about em anyways
first time i was out i was like ''OMG OMG OMG OMG OMG'' then after a couple laps i was chilled
crankin some beats while your in line waiting to have a run chills ya out
after a couple of times going around and just doing some clutch kicks i was entering corners on the handbrake ;)
you think its gonna be nerve racking but its not after a few laps :P
  • Replies 14.2k
I'm not too sure yet man. I've got my eye on a few cars but ideally it'll be something 'S' chassis so S13 or 180sx mainly because their is epic amount of parts available for these, cheap, and I love the styling of them. Smashed up pig S13/180 is hot lol aswell as a clean streeter with outrageous fitment.
Did it take you a couple of laps to get into the swing of things, like basically not sliding the first few laps?
Be good for the first timers if they let us just lap the track a couple times just to get the feel of the track
yeah man, just drive a lap normally, then just clutch kick OUT of corners to get a feel of things
anf before you know it, you will feel at home
next prac will be my first with a handbreak, so will be new beginnings for me aswell
yeah man , just took it easy and got a feel for the track
if theres one thing i learnt , its that mallala is slippery enough in the dry , let alone the wet !
i wanna head out saturday but cant afford to , ill be at the next prac fo sho if i still have my car !
Wayne try and get into a drift school when they have them.
I'll be buying a slider next year I reckon hehe
Yeah man, I do intend on attending one of them courses but the next one isn't untill October and I want to start sliding before then lol
I'll probably be out at the skid prac in August
If there is a private grip day before then I'll even go to that, i don't care what I do, I'm racing haha.
I'll even drag race the cvnt if we had a track in Adelaide :P
grip days are before drift prac
ie in the morning ;)
Don't they hold alot of motorcycle events during the day? I'm more interested in a private day. When is SAU:SA holding another event?1?!?!?!?!??!?111oneeeneeeeOMFG!!ZOR1!!!1
every now n then
im also keen for a private grip day!
every now n then
Keep ya skirts on people ... an announcement will be made soon on the next track day when we can work out a date that doesn't clash with other events (by either SAU-SA or another party). :P
quick !
before my Nissan disappears !
they dont have to go hammer and tongs, and adrift day is limited to 10 spots
surely theres ten people with some sort of testicles in there pants
Just bear with me for a bit. I'm sussing out another option. Holding a drift day for 10 entrants gets heavy on the cash for the entrants. I may have a cheaper option in mind. Need to discuss with the Committee first.
:P
Had I a car to drift with, I would be out there. Give me yours and I'm down like a clown :P
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
