When I replaced my iPaq PDA, I wanted an iPhone ... but the price just wasn't right at the time. Two of the guys in the office have them, and they complain all the time about something wrong with them. I figured I'd just get a 'normal' (read: boring) phone for now ... altho my Nokia does have touch screen for easy use and internet access (3G) albeit slow. :P
Ive had mine for 15 months and it hasnt missed a beat... ever!
Gotta love mass hysteria :angry:
  • Replies 14.2k
Its 14psi man, and if it weren't my engine would lean out and go BANG! as I only have standard injectors. And the standard boost gauge represents 14psi where it hits and sits all day everyday
14psi is the end of the Boost Gauge, just because the needle stopped doesn't mean the boost does too haha. You were probably running 15-16psi + the cam gears that got you to 270
I'm. Running. 14. psi. dammit. lol
It was tuned and the boost was monitered and didn't move from 14psi right through to 7,500rpm lol
But yes, no doubt the adj cam gears did help but they're nothing 'too' fantastic but can make a massive help when tuning.
Have you heard from shaun? Does you car have adjustable cam gears?
I cant access all features of OS4 because I only have the 3G (as opposed to 3GS) but it still looks pretty, and works better.
I was told that the redsnow jailbreak will allow 3G owners more features. I won't update to OS4 just yet however
Can someone help me out with a paypal payment? Its only $50, but its for a part I need in the post asap. Will get the $50 to you asap.
Long story, but I've close my bank account that I use to have my paypal linked with. Now I have no paypal set up properly.
PM me if you can help ... thanks :angry:
Thanks for the offers guys. I've been sorted out now. Thanks Abe :P
I got a 3GS a couple weeks back for free so I thought I'd give it a go and I'm very impressed considering I didn't think that much of the original version the Mrs had when they first came out. Obviously jailbreaking makes them so much more worth their price imo
No cam gears at all and no idea why I'm running only 9psi with no boost restrictor. Man I'm so devo, I'm sure my old R32 would of had more power.
:cool:
heslo = epic post whore in the last couple of pages lol
heslo = epic post whore (fullstop) Nuff said :P
Haha beat me to it Andrew ;)
You are a little floozy whore Lukey Boi........what party tricks can you perform :P
You should've come to Kadina mate :cool:
:/ Cheers guys, feel special I do!
I would have Pete, but had other things on. Next time I promise
What Dohmar is saying Wayne is that no Skyline EVER has run 280rwkw with standard turbos and injectors. Go check the RB26 power threads if you don't believe me.
The ninja GT-R lol
f**k knows with these imports hey!
:cool:
Performance cars are cvnts.
Compression/leak down test is next!
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
