  • Replies 14.2k
yeah "Ph <1"
depending on the concentration that could have ur hand off
hence why the instruction says wear gloves and goggles before using this stuff.....and a PH<1 is will go through anything as it is highly corrosive :P
What is this thing you call "soccer"? Sounds like some poofy game where it is more interesting to watch the grass grow on the pitch, rather than the so-called "action" on it ....
ok checked out agreement and it just says repairs need to go through the office of the agent which is fine i do that, but fuse and other little things i do myself. The heater blew up over a week ago and that needs to be fixed cause locky is just getting over a cold and there should be no reason as to why i cant have one since there was one when i signed the lease and i dont really care if he cant afford one find the money i say otherwise dont have a rental property
the mo-flo states that it contains sulfuric acid 1835g/L with a black diamond saying corrosive 8
I called joe blow the plumber out of the yellow pages and he said that stuff has to be used by someone who knows what they are doing with that chemical and that it you should be wearing protective clothing ect and that you cant buy this stuff over the counter you have to go to a plumbers supply shop to buy it
if it gets out of hand, the rental tribunal is there to help. probably wont need to get to that...
its pretty surprising that the landlord has some of that mo-flo stuff lying about, they really dropped the ball on their duty of care on that one. being given that stuff, and having to do it yourself is all ammo in your arsenal for getting this resolved.
if it were me in your shoes, id be wanting the landlord to have all of this fixed by COB tomorrow, its not your problem that he has to wait to have the money for the repair, that is what cash converters is for :P
you just like watching grown man hugging dont you Andrew :P
for the heater get the agent to get on the landlords ass and get yourself one.....with the mo-flo well there is your answer....you being in the state of pregnancy should be no where near that stuff.....and obviously your average joe doesnt have the proper training in handling that stuff either......so if i were you then i would be getting in touch with the landlord and the agent and sort this out as the landlord carelessly put you at risk by giving you this "mo-flo" to do a job that needs a professional to look at it.....so basically your landlord was just trying to save $$
Seems your landlord may have just opened himself i big can of worms, considering it has a corrosive rating of 8 pretty sure legally you should have been supplied an MSDS. Especially seeing as it was used in an enclosed environment by an untrained and unlicensed person, and obviously in an improper manner as it will chew through DW rated PVC in no time if mixed incorrectly. I'd be reporting this to the Tennancy Tribunal and also to the agent as obviuosly the fumes have put you at risk.
I have called the landlord and she will call be back (famous last words)
I have sent a sms to the landlord if i havent herd anything ill be calling
as for the mo-flo its living out side hidden in the garden cause i dont have any lockable area for it
i have to get locky from school ill keep you all posted and thanks guys carl i might need to contact you and pick your brain if need be about taking this further if need be :P
ok boys i need some help.
My drain has been blocked for about a week now (I think its blocked) when you have a shower the water comes up out of the drain on the floor which is under the bench told agent at the inspection last week and the landlord sent his mum here about 15 min ago with some stuff in a black bottle saying sulfuric acid for drains, I read the instructions and poured 1/4 of the bottle down the drain and stand for 5 min then flush with cold water but it started smoking and had this really bad smell, i put a folded up towel over my face and held my breath and put the bath tap on and the smell has gone through my house and i have thrown up everywhere out the front. WTF
Ring a plumber with a drain snake!
Draino, and other drain acids will do f**k all!
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
    • I'm late to the party. Been busy with a newborn... Keeping me up at all hours of the night.  I'll look into purchasing ID 1750's then! Thanks everyone for the concrete evidence.
