  • Replies 14.2k
Might be a little bit biased but yerp! You won't regret it, strong as all hell, brake upgrades are easy...Only thing to remember is parts are hard/expensive to obtain and its not like a s13 or R3x series skyline, you can't just get parts for them from anywhere unfortunatly....But very rewarding cars!! Just need a lower seating position in them...
This was on my mind about parts but at the same time I'd only be able to drive the car at the most, 6 months of the year and I don't think I'd even drive it half that.
Just saw it, can get it for a decent price and thought it would make a decent daily for when I'm back on shore or maybe a project to make it original again.
Going to go check it out this Sunday now and if it's all sweet I'll probably buy it :P
Started my truck licence today...Man some many bad drivers who don't give a shit about them! Seen a few aftermaths of accidents as well...Interesting day for sure
welcome to my world boof. i get equally annoyed when cocks pull in front of me when im towing with the pootrol, let alone driving an MR truck (and ours with EWP/Tools/other crap tip the scales around 13-16T too). They think cos we can accelerate as quick as most cars (well, newer trucks anyway) that we can stop as quick
Only good thing is merging..............stick the indicator on, if they wont let you in, just start moving. They make their mind up pretty quickly LOL
Is it advertised online? Make sure you check for rust, check around the front strut area's for rust, check the sump make sure it hasn't been bashed in (there's bugger all gap between the bottom of the sump and the pick up and the sump swings low and proud at the front)...But the motor's are strong as f**k, the diff's are plated R200's (not the viscious crap) probably weakest link in driveline is the box but you can do 32 or 33 boxes in them easily enough!
HAHA yerp i learnt that yesterday, put the indicator on and pull over lol! They'll move quickly! Enjoyed it muchly but was very drained last night when i got home so much to do!
as u guys know. im starting a new job on monday.. for the lols i got boozy on monday night an made up my letter of resignantion. it was difficult to be funny without being nasty, but this is what i handed in
**FYI new yorks is the name of the coffee shop that i always went to
To: Telstra Corporation Limited. 21/06/2010
This letter is to confirm my resignation from Telstra Corporation Limited, effective as of COB Friday 25th June 2010. In Order to assist with my reasoning behind moving on I have constructed the following graphs:
Also, here is a picture of a spider with seven legs
Sincerely,
Carl *******
Employee ID: D******
Woot!
Finished the last Exam for my degree at 12 today, One more semester and two more subjects (No Exams) to THE END.
Have to work tonight so no partying unfortunately, but had a couple Dimple_7523.jpg's this arvo which wil tied me over until Monday
Edited by D_Stirls
Woot!
Have to work tonight so no partying unfortunately, but had a couple 's this arvo which wil tied me over until Monday
Congratulations Mate!
I had my F**K EXAMS afterparty in town last night. I had many a beverage lol. Woke up in a house at Henley Beach, got home at 2pm today. Basically the first half of today (and some of last night) was the same storyline as Dude Wheres My Car.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
