  • Replies 14.2k
first day at work with the magistrates court was a sucess :D
good ppl and interesting work... already seen 2 ppl i know rock up to sort out their fees/fines.
had a celebration dinner on sat night with teh mrs. bought 2 300gm cuts of wagyu grade scotch fillet... at $90/Kg it is worth every cent! nothing better than a rare primo quality steak to get me going :cool:
I'm filling out my new contract and came across these thing that i dont know what they are or dont know how to find out where to find them.
SWIFT code
(Compulsory for ALL countries)
IBAN Code
(Compulsory for EU countries)
ABA Code ( for US)
or
BIC (Bank Identification Code)
It's for my pay to go in so I'm just wondering if i need them or not.
cheers
i think i may have just taken somebody's speeding fine.
South road, next to Mitsubishi's, there is a speed camera in the bedding place across the road, in the car park. I see the silver ford wagon, and assume it is a speed camera, so i go from 60, to 55kph, just to be safe. Meanwhile, i notice a car coming up my ass at a decent rate of speed, in the right hand lane.
so i pass through the camera, and it doesnt go off, but this car has flown past me, and the camera has flashed, as he is on my front quarter. Leaving only my numberplate in view.
The camera only flashed once, which i was suprised about. But being quick to think, i grabbed his rego, the make, model, colour, and time of this car, and noted it down on my phone.
Basically, i am waiting for the letter to come, assuming it's me that they think was speeding.
What can/should i do?
I'm on my P Plates, have been driving since i was 17, and am now 20, and have survived on one point for 2.5 years, and i really don't want to lose my licence for somebody elses disregard for speeding.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
