  • Replies 14.2k
While we're talking tyres, who wants to spot me $240 so I can get some replacement tyres for the AWDTC Time Attack next month?
:rofl2:
Doing my brake upgrade, paying the mortgage, and on one income is slowly killing me :D
I have JIC coilovers in the ass end of the 180,
And the locking tabs are bigger size then the fronts to lower it, the fronts are as per normal any other coilover locking tabs I've ever seen, so my c-spanners dont fit... I dont want to take a chisel and hammer to the locking tabs so does anyone know where I can purchase a set of spanners to suit a bigger locking tab? Looked on eBay, nothing...
I need to shlaaaam the ass end of the 180 yo
:D
Doing my brake upgrade, paying the mortgage, and on one income is slowly killing me :)
what pair of tyres will you be getting for $240
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
