Isn't that normal because the oil breather plumbs into the intake pipe before the rear turbo? I may be wrong.
if thats the case, its not a related issue. should really take pics of my piping before I clean it out... theres too much oil in there to be normal
-D
  • Replies 14.2k
random question
Does anyone work at a place, or know where I could get a 6 way TV splitter tomorrow? like a Hills, or a Clipsal one?
Just spent $73 on a HD set top box to find out my TV in my gaming room isn't connected to the 4 way splitter in the roof... grrrr
/rant.
jaycar
Interesting, you can lease an R35 GTR MY10 Premium
FULLY maintained: $ 3,773.34 per month inc. GST
ill keep that in mind if i ever find an extra $4k a month burning a hole in my pocket.
Dion i need cash for the clutch this weekend, i thought the manufacturer was going to send them through and i pay later but its cash first i can come out to you if its hard for you to get about txt or ring me when you see this 0421932750
Well that was good timing, seeing as I just got up lol
I want these for my rex. I got some saving to do but what do you think?...
http://cgi.ebay.com.au/18-ROTA-GFORCE-WHEE...=item19b7fa3c7c
HELL NO! Get geniune works for that price and your not giving money to a company that blatantly copies other company designs.
Sent you a text before, Im guessing youre at work... Or my last text didnt work lol
Here is there whole cataloge
http://www.rotawheels.com/wheelcatalog.asp
All of them are direct rip offs of Work Emotion series, Work Meisters, Rays/Volk and Advan racing.
And unfortunately they don't "slightly" change them like Drift-Teks did compared to the Bee-R orignials.
As soon as I seen them I was like :( 11R's wtf? lol
:D
You could get genuine works from streeter sent in whatever offset you want for probably $1,600.
:D
The Rota G-Force is a copy of the Advan RS wheel.
11R's are very similar to Advan RS-D which is basically an RS with Dish.
Every company has similar looking wheels, and it depends what you want to run on your car - i.e. $3k worth of rims (genuine advans), $1.6k worth (work) , or $1k(rota). Its a personal choice.
Personally, I bought second hand Gram Lights 57Fs (forged) as they suited the car and application better, BUT i did consider the Rota G-Force at one stage as there is no way I can justify $3k on rims
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
