  • Replies 14.2k
Never understood the SA obsession with FUIC .. As an outsider, I guess I never will ;)
theres just not enough bogan in you
any good tradie or non coffee drinker can attest that its one of the best liquid brekkys available
couple that with a bacon n egg mc muffin, u got the bogan breakfast of choice
-D
When you come from the far northern suburbs, its easy to understand :P
Happy Birthday Andrew!
and random fact for the day, I went to the same high school as you Andrew ;)
Thanks guys ....
and by high school Dion, I take it you mean Banksia? I only did year 13 there to top up my Uni entry scores .... I actually went to St Peter's College year 8-12.
It is the nectar of the Gods.
That is all.
amen
westminders > st.peters ;)
oh and thanks for the support Ive received re: mental health
thanks, means a lot to be perfectly honest
anyone suffering depression and/or horrible thoughts seek help, please
beyond blue.org.au 1300 22 4636
lifeline.org.au 131144
took myself off my anti-deps 2 weeks ago 'cause they obviously were NOT working, seeing head shrink tuesday
stopped cigarettes well over a month ago along with maryjane; dont miss it one iota.
however I do firmly believe prescription Marijuana should be made freely available to pain patients.
ordering a Hasa carbon/alloy road bicycle. real keen to make some tree trunks (again)
http://cgi.ebay.com.au/NEW-HASA-CARBON-ROA...=item5ad9ea3f6e
cant swim, nor weights with no knees. with patellas couldnt cycle due to the bone-on-bone, but now with tendon-on-bone the cycling seems the best motion
so, going to start slow with 10km rides and get to 60km rides hopefully (ie city&back, mt.compass&back - yup willunga hill is the goal)
will take pics of legs prior to 1st ride, then after say 100 rides. mantrunks here we come again (used to be able to bomb a goal from outside 50m no worries, best goal was over Fitzy 60m out at Pt.noarlunga)
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
