  • Replies 14.2k
watching a doco on future weapons. The USS Dwight J Eisenhower (Aircraft Carrier) was recently overhauled, now has 2 nuclear reactors and can stay at sea for 25 years. The Super Hornets can go for 40% longer, and the weapons are connected to the pilots helmet. They have a heads up display, and it aims the missile wherever they turn their head, and fires with a nod of the head!
*nods head
And aircraft carriers now sport anti UAV/missile laser systems. Cool stuff
And they have a 'heat weapon' getting deployed to iraq at some stage for crowd control - basically a big microwave oven mounted on an APC
-D
-D
or a humvee. theres also a version small enough to loosely be described as squad portable. its called an 'active denial system' or some such.
Looking at new steering wheels.. Ugh.. Like a woman shopping for new shoes..
Always loved the Nardi Classic I got when I bought the car. gonna have to get it retrimmed tho cause the leather is worn to buggery
-D
yup. got a nardi torino on its way for the s14... already talking about swapping it for a personal.
Have you considered re-conditioning it? Leather, being what it is, can quite often be brought back from quite hideous states to near-new.
I recently did this on both of my cars, and the 12 and 17-year old steering wheels now look near-factory.
tried that, they're too far gone unfortunately. needs new leather ;\ wont cost much to get done fortunately
-D
Ive still got the standard Type M steering wheel (same as GTR, but Skyline logo horn button). The leather on that is way gone aswell, will get it re trimmed soon - add it to the ever growing list of things to do haha.
I wish I had some before-after to show you guys how far gone you can still 'fix' a leather steering wheel. My N14 wheel I had written off and been wanting to get re-covered. I figured I was gonna re-condition/re-dye the R34 wheel, and so I'd give the N14 a go for a laugh, and I'm honestly stunned at how well it's come up.
I used the product from PPCCO - http://www.ppcco.com.au/kits6.htm
Damn cheap really, though lots of prep work with various treatments, sanding, filler, etc depending how far it's gone. I figured for $50 it was a cheap chance to have a go and see if it would work rather than forking out $250+ on the two wheels on my cars .. Eh, hey - each to their own. I don't mind trying a bit of DIY - figured I couldn't be in a worse position if I messed it up.
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
