  • Replies 14.2k
setup my bicycle and went for a ride just before
came inside afterwards, took the step down into the family room, leg didnt hold and crumpled to the ground !!!
left knee totally gave way
wowsers
This is a 12-13 inch pedobear plush toy for sale!
He is the pedestrian bear, see him run!!!!
he is made in his classic running pose
it is made to a high quality and could be a perfect gift for children ;)
:D
Goodmorning!
How tough is the scruteneering on tires at Mallala?
.. Also, do you have to wear gloves and do your shoes need to be leather?
I am awere you are to wear flame resistent clothing from ankle, wrist to neck... I dont want to rock up and not pass because shoes and gloves or whatnot.
Thanks!
Goodmorning!
Thanks!
I am not too sure, are you asking about the SAUSA track Day? I suppose as long as it's road worthy, It's fine. You need a Helmet, and a long-sleeved top - I wore a White Boiler Suit last time ;), and just some sneakers.
Hey Andrew, I found you a new Ban Stick :P
    • How would i degree my cams on an rb25 hydraulic lifter head? lots of information online about degreeing cams on NEO or rb26 heads with solid lifters but cant find a definitive answer about hydraulic lifters. is the process just the same for both hydraulic and solid lifters on an rb (dial indicator on top of the lifter for measuring valve position) or do i have to mess with my lifter to make it solid for the degreeing process?
    • Hmm. Two terminals. Probably just conductivity. If you knew the shape of the curve, you could probably just do it with a multimeter.
    • Clinton and I spoke to Alan Heaphy at length last year at the Bathurst 1000 about the Gibson GTR's that he had at the track and the restoration work that his company was involved with. He has a number of people working for him who were part of Gibson Motorsport when these cars were being built and raced. What impressed me the most was the amount of first hand knowledge and information that he and his team have about the Gibson GTR's and their meticulous attention to detail in the restoration and maintenance of these cars.
    • When you track RPM vs time it's clean, unlike the OEM one, even with filtering there are ripples. Means no random misfires or triggering issues at higher RPM, especially if you have big lift cams and a noisier valve train due to heavier springs.
    • Brake Fluid testers are cheap and readily available....eg https://www.supercheapauto.com.au/p/endeavour-brake-fluid-tester-rechargeable/SPO9539349.html
