  • Replies 14.2k
have given up on trying to fix0r the 32, gonna hand it over to my mechanic
the power steering pump wont pivot cos the lines are too hard. so i cant get the damn belt on. i really didnt want to crack the power steering lines and have to deal with the mess and a poorly bleed power steering system.
probably a good thing, i'll get all of the belts swapped and get everything checked out
Lol, thats why i quoted Vu's post and congratulated him on the 14000th
f**k. lol.
One of the Economisists at UniSA emailed me this link:
http://www.peterrussell.com/Odds/WorldClock.php
Pretty scary stuff.
f**k. lol.
Pretty scary stuff.
Not Ken Adams by any chance?
Hello!!
After getting tires last night I had a chat with the guys at Speed Factory and they are willing to offer discounts for SAU club members, all you need to do is call up and say Penny refeered you and they will give you a special price.
http://www.speedfactory.net.au/
Quickie:
What do the numbers mean that are on the coil packs of R34 and Stageas? Stagea are marked 922 (I think) but R34 Neo coil packs are marked 933.
Any ideas?
f**k. lol.
Pretty scary stuff.
yeah i got this one when i did microeconomics at UniSA
Ken Adams sent it.
kinda makes you wonder how accurate it is?
Hello!!
Sounds good Penny. Can you shoot Shane a PM letting him know of the possible arrangements?
    • 1. Factory knock sensors for now, honestly the RB26 OEM knock sensors seem ok as they're flat response instead of resonant type but they appear to be internally grounded to the block. If I do replace the sensor it would just be to get ones that are not internally grounded so a differential input can be used to reject common mode noise. Definitely plan on fixing this as a part of the tuning process. 2. Never deliberately induced knock, though I guess I could try that experiment if I really wanted to. 3. All of this is basically on a stock engine + ECU, only modification is HKS GTIII-SS turbos and a Nismo plenum. Currently I run it with the wastegate solenoid unplugged so it won't try to raise boost past wastegate pressure.
    • After being peer-pressured into paying $100 for the MW remakes, got BO6 on XBox Game Pass. I think that's worth it.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
