  • Replies 14.2k
need someone who can flare my guards, and i dont care about paint.. any want to do a cashie?
also called AM performance to get all new cooler piping dont (quote) said he would get back to me yesterday.. no deal!
thought he was the best!?
Give him a break bud. Having just come from his workshop, we're all flat out prepping for the Autosalon stand plus he's got a backlog on orders too. All up, he's just snowed under. Best bet, swing past, have a chat and he'll sort ya out.
Penny, they actually aren't too pricey at all, Andrew does some quality stuff at very competitive pricing, I wouldn't trust anyone else. Plus the care he takes on your car is second to none
Thats so damn true.....he actually takes a lot of care in getting his work done.....and he wont be happy until your satisfied with the work done......awesome customer service
I'm buying a new TROLLEY JACK, must be the low profile ones. Who knows where is a good place to grab one?
Something like: http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWAX:IT
this is the tool mecca, but confirm price to ship
Alloy low profile jack
BKR6E vs BCP6RES
Projected tip vs Projector insulator
The BCP plug overall looks a bit longer, NGK recommend the BKR. However there seems to be a fair few people around running the BCP plug, are there any actual benefits to this plug?
I'm running BKR6EIX in my 25det, this is more of an interest question.
What is a really good spray on wipe off product for a cars exterior? To give it a good temp shine. Heard of it but can't recall what it was.
also interested in this too.
All i know is Armorall = BAD from what i hear / read.
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
