  • Replies 14.2k
pretty sure andrewjzx100 wants it
Yep, that 20 is mine :D
Just went and got the car running so I could drive it to my mates for the swap and I must say boost is good fun after driving around in nothing but a 70s Cressy for a month and a bit :thumbsup:
Ok, well I had my RB20 compression tested this morning and:
1: 92
2: 88
3: 80
4: 85
5: 90
6: 90
So obviously not too good. It's got oil in the water but Ive been told its likely un-related to the low compression as its across the board, not just 1 or 2 cylinders. My mechanic told me its either due to valves not sealing, or the piston rings. So realistically, where should I go from here? Please spare me the comments about selling it or converting to a RB25/26...
Rebuild. Or replacement. Doing a huge, expensive rebuild is pointless on a RB20. If you're going down that path, RB25 it.
Was the low compression from the blown turbo then?
Edit: scrap that. Just quad-rotor it. Cummon. Do it. Or 20b it. Do it. I dare you. No. I DOUBLE dare you.
Edited by CRoNic...
Yeah I do agree on the huge rebuild thing, but I'm not sure what you mean with the blown turbo... I thought it had a blown turbo - but apparantly not, there is a chance thats gone too though.
If your going the sensible route, grab an RB20 block and drop it in, will cost you f**k all and youll be back on the road sooner.
JIS have an engine, loom and ECU package for $1950, grab it, sell off the loom and ecu, sell your f**ked 20 for peanuts, some parts could be valuable to someone else.
Or JMS have an R32 front cut, no gearbox, low kays for $1500. Grab it, keep donk, sell parts, ??????, win.
RB24...that is all :thumbsup:
Oh right, I just remebered reading that you thought you blew the turbo on that Berri trip a few weeks ago? So it was actually something worse?!
Yeah I thought I blew the turbo, but further investigation points me towards the motor, and then the compression test confirmed it. Like I only discovered yesterday when I was pulling the crossover pipe off to do the test, that Ive got oil leaking everywhere (both valve covers, pcv valve etc), but the crossover pipe was dry..
I am quite tempted to go the RB25 route (just got off the phone to Paul from AdelaideJap), but I really dont want to go in over my head so I'm clinging to the 20 still.
I'd love to build an RB24, but everything that Ive read suggests this isnt the cheapest thing to do...
I was talking to Adrian about his 25 swap. He regrets the swap because the 20 can take abit more abuse.. but you get better results from the 25.
All depends on what you want from the motor and what you do with your car.
I don't know how much it would cost...but 2-2.5k should do it, ill scan a article out of HPI #44, where they start building a RB24, and send it too you.
The 25 is a better long term solution, and it'd be less labour involved I'd imagine - would be a better starting block for engine mods too, cause that extra capacity really helps
-D
mate i've just being driving an automatic hyundai getz around cairns for a few days and let me tell you what a heap of shit! Gutless as all f**k as well
LOL sounds like the one I drove in the Gold Coast, couldnt farking stop , couldnt get it to go.
boot space less then the R34... what a joke of a car. (it was even brand new) disposable car
-D
that it does Ben...Dion i know you want to drop a RB26 in there mate....do that instead
thats tuff luck dion, damn old cars
on the subject of old cars, check out this 240 :)
http://www.carsales.com.au/all-cars/privat...6&silo=1011
you got that cash lying round dont ya
Edited by Inline 6
Guest
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
